Winch question
Discussion in 'General Tundra Discussion' started by Barrel85, Oct 24, 2020.
  1. Oct 24, 2020 at 4:06 PM
    Barrel85
    Barrel85 [OP] New Member
    William
    2018 Black Tundra TRD
    Do I need an in-line power switch for my winch? I’ve got the positive lead ran straight to the battery. Wondering if I need to put a switch on it in case of a parasite drain. Thanks
  2. Oct 24, 2020 at 4:55 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I have the positive lead running straight to my battery for about a year, never had any issues. I’d say you’re fine
  3. Oct 24, 2020 at 5:11 PM
    Barrel85
    William
    Thanks. Was just wondering
    TG705[QUOTED] likes this.
  4. Oct 24, 2020 at 6:24 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    I have mine wired to the battery, there should be a switch on your winch. Never had an issue with mine.
  5. Oct 24, 2020 at 7:02 PM
    Barrel85
    William
    I don’t think my winch has a switch on it except for the wireless feature. It’s completely hidden in my bumper So no access. That’s why I was wondering about a switch under the hood at the battery. I have 10k smittybilt
  6. Oct 24, 2020 at 7:22 PM
    41bigdawg
    Robert
    Tennessee
    2013 Tundra DC 5.7
    I have a Smitty 12k, there is a switch on the side of the control box. Some members on here relocate the control box up under the hood. You could put a switch up top if you can't get to the one on the control box. I always leave mine off till I'm ready to use it.
    realtorblake likes this.
  7. Oct 24, 2020 at 7:45 PM
    Barrel85
    William
    Thanks. I’ll recheck mine tomorrow. I could only move my control box to the side of my winch(no more cable length). I’ve had it hooked up for a few weeks now but was just being safe. Had a dead battery and want to eliminate any possible drain.
    41bigdawg[QUOTED] likes this.
  8. Oct 24, 2020 at 8:07 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    It’s best to have a cut-off for your winch so if you get in an accident, or somehow it powers up, it doesn’t eat itself (if the hook is attached to the bumper, so it doesn’t destroy the bumper). Most do it with a ~450A breaker type switch or HD cut-off. I’ve done it straight to the battery and with a cut-off. If you have it straight to the battery, make sure you keep it in free spool mode. As far as parasitic drain, no concerns there.
    Mater likes this.
  9. Oct 24, 2020 at 8:35 PM
    Barrel85
    William
    Thanks for the info. I’ve been doing some research and found that leaving the winch on “ wireless” mode could cause a drain. I think that’s my problem. Since I can’t reach my winch I’ve kept it in wireless the entire time.
  10. Oct 24, 2020 at 9:01 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Gotcha. I’m not familiar with that aspect.
  11. Oct 24, 2020 at 9:10 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    As @The Patriot 1776 said, be aware of your winch and it’s wiring. There are stories of hooligans going up to trucks with older warn winches and jumping the controller pins (only 3 of them so not hard to do) leading to the winch motor burning up. Gotta be careful because your truck can burn to the ground
    The Patriot 1776 likes this.
  12. Oct 24, 2020 at 9:16 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    This...
