Winch bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fortis32, Aug 14, 2019.
  1. Aug 14, 2019 at 7:10 AM
    Fortis32
    Fortis32 [OP] New Member
    Nicholas
    Pennsylvania
    2018 Tundra SR5 Double Cab
    I want to install a prerunner style winch bumper. Am I going to need new struts for added weight or can i just get a spacer lift and call it a day?
  2. Aug 14, 2019 at 7:22 AM
    You may need a different set of coilovers. There are some pretty budget friendly options.
    Check the vendor section. Toytec has a lot of options and great customer service.
    Mwray8909 likes this.
  3. Aug 14, 2019 at 8:14 AM
    ctdomain
    ctdomain Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    ^ Exactly as above. Just make sure you get a coil over with a spring lb. that will hold whatever it is you are putting on the front. Putting in a spacer lift may remedy some of the sag, but I would think without upgraded coilovers you would be bouncing all over the place.
  4. Aug 14, 2019 at 8:25 AM
    Bigbird57
    Bigbird57 New Member
    Get the Bistein 6112's
    Use synthetic winch rope. A great weight saver.
  5. Aug 14, 2019 at 10:54 AM
    Fortis32
    Nicholas
    Pennsylvania
    Thanks for the information. I've had 2 trucks in the past left bone stock so this is my first go at this. I'm confident I can even handle the install with my mechanical inclination as well as modding my motorcycles in the past. I'll just get an alignment afterwards of course
  6. Aug 14, 2019 at 12:59 PM
    Fortis32
    Nicholas
    Pennsylvania
    Do I need to be concerned about rear sag with a 2" front lift and no rear, if I have a 400lb tongue weight trailer?
  7. Aug 14, 2019 at 1:08 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Before you consider modifications to the front suspension, make your choice regarding bumper, winch, and rope (cable vs synthetic). This will let you figure out exactly how much weight you are adding, so you can tell what changes are needed.
    With a hidden winch setup & synthetic rope, your net weight increase could be under 80lb. This could be compensated for by only adding a single CB shim on both sides.
    On the other hand, a ranch hand bumper/grill and wire rope, could easily go over 300lb.
  8. Aug 14, 2019 at 1:11 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You will probably be surprised at how little weight it takes to give your Tundra a visible squat. I believe it’s best to have a little rake, with the rear a few inches higher, so with small loads and trailers, it’s leveled out.
  9. Aug 14, 2019 at 1:15 PM
    Fortis32
    Nicholas
    Pennsylvania
    I wasn't aware of hidden winch mounts thanks for the info
  10. Aug 14, 2019 at 1:23 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My truck
    My truck has one. SDHQ in AZ is the manufacturer. There’s several others.
    ntg and Sonicbluerider like this.
  11. Aug 14, 2019 at 1:24 PM
    Fortis32
    Nicholas
    Pennsylvania
    Nice clean OEM look. What size tires can I install in the case without coilovers?
  12. Aug 14, 2019 at 2:45 PM
    ctdomain
    Clint
    I believe (and someone correct me if I'm wrong here) that your front suspension already has coilovers. However, some aftermarket coilovers (King 2.5 Coilovers Extended for example) allow you to achieve a greater "lift" without compromising the ride in the front. With the stock suspension, there is a thread which i will link here --> https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/ which will hopefully help to answer your question about tire size on stock!
  13. Aug 14, 2019 at 3:09 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    The stock bumper weighs about 45-50lbs. You replace that with a simple tube bumper that weighs on average 60-75lb. Then you add a 80lb winch with synthetic rope. You're going to easily be over 100 on the front compared to stock.
    SpeshulED, Mwray8909 and gosolo like this.
