Will this wheel/tire setup work?
Discussion in '2nd Gen Tundras (2007-2013)' started by Sergef, Nov 17, 2016.
  1. Nov 17, 2016 at 9:58 PM
    Sergef
    Sergef [OP] New Member
    Sergey
    Im looking to get new tires and rims. I really like how 305/60/18 tires look. Also want to match them up with some Fuel Hostage Wheels (18x9 5x150 +01mm offset). Right now my 2010 Tundra 4x4 has a stock suspension. Thinking of getting a leveling kit later on but, I havent decided yet. Will this setup fit with the stock suspension? Or should I expect some rubbing?
  2. Nov 17, 2016 at 11:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm gonna say you're definitely going to rub somewhere. Closest to that size might be @bluebooboo
  3. Nov 18, 2016 at 12:13 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    And if I'm not mistaken ... bluebottle is leveled 3/1.5 too and had rubbing issues. He's running a slight taller tire though, but his offset isn't quite aggressive.
    And welcome to the forum Sergef!
  4. Nov 18, 2016 at 1:35 AM
    chphilo
    chphilo Tundra addict
    Western PA
    That's not very tall tire at 32.4 inches. But that's a very aggressive offset. My guess? Not sure. You might get lucky. (every truck is somewhat different)
  5. Nov 18, 2016 at 8:48 AM
    Sergef
    Sergey
    I've also thought about going with 295/65/18. Ive read on other forums that they fit well with no rub on stock suspension and wheels. Im just hoping that will also be the case with the offset im going with. Im willing to trim plastic if I have too, I just want to avoid any rub on mechanical parts. Anybody have any experience with 295/65/18? @chphilo @r4z0r51o @joonbug
  6. Nov 18, 2016 at 8:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Are you set on the +1 offset?
  7. Nov 18, 2016 at 9:08 AM
    Sergef
    Sergey
    I was looking for +10 or +12 but, those fuel hostage wheels are +1
  8. Nov 18, 2016 at 9:29 AM
    r4z0r51o
    Dave
    I have on order a set of Fuel Nutz 2 piece (D251) wheels 20x9 +20mm with Toyo OC ATII 295/60 on the way (Hopefully by next week) that I expect some minor rubbing. I'm expecting that I'll have to remove some mud flaps but no CMC. My concern for you is the aggressive +1 offset. I thought about going with a +1 offset, but believe that would require the CMC which I don't want to do. Fuel make the Hostage in a +20 ... that should still have about an inch, inch and a half of tire sitting outside your wheel well.
    Here's a pic of my current set up of my OEM wheels with 1.25 inch spacers which puts me at about a +28mm. These are 18x8.5 (I believe) with 275/65's. So I'd guess 18x9,+20, 295/65 would sit out another 20mm.
  9. Nov 18, 2016 at 9:35 AM
    TheBeast The Beach
    I was running 305/60/18 Pro comp Xtrem tires on +18 offset wheels with a 3/1 leveling kit. No rubbing unless heavy load.
    running 33x12.5x18 now on same wheels. A bit more rubbing on full load when turning in reverse.
  10. Nov 18, 2016 at 9:36 AM
    TheBeast The Beach
    wheels offset make a big diffrence or what you can and cannot run. Choose wisely.
    r4z0r51o likes this.
  11. Nov 18, 2016 at 9:41 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    yup, getting the +20 will probably make your life a whole lot easier.
    TheBeast and r4z0r51o like this.
  12. Nov 18, 2016 at 10:09 AM
    Sergef
    Sergey
    @r4z0r51o If the Hostages come in +20 offset, I would much rather go with those instead of the +1. I like your setup man, looks really nice.
  13. Nov 18, 2016 at 10:31 AM
    r4z0r51o
    Dave
    Sergey, yes the Fuel Hostage is available in a +20 offset. If you'really not in a hurry and can wait, I'll post some new pics of my new stuff when they arrive. Maybe that will help you see what a +20 on a 9" wide wheel with a 295 will look like. At least width wise ... I can also report any rubbing issues.
  14. Nov 18, 2016 at 10:45 AM
    Sergef
    Sergey
    I actually checked out those Fuel Nutz and Im really digging them. Maybe I'll switch it up a bit and go with 20x9 +20 Nutz and 295/55/20 Tires. @r4z0r51o
  15. Nov 18, 2016 at 12:03 PM
    r4z0r51o
    Dave
    The Nutz 1 piece (D541) cost about the same as the Hostage (D531) which is also a very nice wheel. However, they (the D541) only come in the machined finish. If you want black you'll need to go with the 2 piece ones (the D251) which will cost nearly twice as much.
