will the 1794 wheel fit 2012 Sequoia ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tomminator855, Dec 6, 2016.
  1. Dec 6, 2016 at 8:45 PM
    Tomminator855
    Tomminator855 [OP] New Member
    i know this is kinda off the topic , my wife 2012 SR5 Sequoia needing a new set of tire ,currently is running on a stock 18" 265/75/R18 tire , but i found a local craiglist ad for almost brand new set of wheel and tire that he took off his brand new 1794 or platinum truck for a great deal 750$. so do you think the fitment would be any problem for a tundra wheel to Sequoia ? thanks guys
  2. Dec 7, 2016 at 4:03 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    My research online says the 2012 Sequoia has a 5x150 bolt pattern. That is the same as the Tundra. The 1794 has a 20" rim. So you just need to compare the tire size of the 1794 Tundra versus your existing Sequioa. You can call a few tire shops and ask if the larger tire size will fit as well.
  3. Dec 7, 2016 at 7:15 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    If @1UPPER is correct on bolt patterns, you won't have any issues. However, if I'm not mistaken, the stock 20" tire size for the Tundra is 275/55/20. Using a simple tire size calculator, I'm compared the two. The Tundra tires are nearly 1.5" shorter and have 1.8" less sidewall; but are almost .5" wider. IMO, the Tundra tire will look way too small on the Sequoia.
    I would confirm the Tundra size from the craigslist ad, and look at a tire size calculator yourself so you can visualize what I'm telling you.
  4. Dec 7, 2016 at 12:10 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Confirming that the tires on my 2016 Platinum are P275/55/R20
  5. Dec 7, 2016 at 8:14 PM
    Tomminator855
    Thanks guy i've got the wheel and tire installed and they fit perfectly , looks good too just now i have a seqouia and tundra that have exactly the same wheel park in front of my drive way hahaha ... really appreciated your help , y'all the best
    MotoTundra likes this.
