Will stock lugs work on aftermarket wheels?
Discussion in 'Wheels & Tires' started by joem1cha3l, Oct 7, 2016.
  1. Oct 7, 2016 at 8:15 AM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Went with Ballastic Morax wheels.
    USPS has been so kind as to lose my shipment of lugs, so now I'm either forced to be patient and hope they show up sooner than later, or use the stock lugs in the mean time. Any thoughts?
    Can't remember if the stock lugs taper or not. I do know the lugs holding my Spidertrax on have a taper to them and they're getting removed...
    Hmm....
  2. Oct 7, 2016 at 4:10 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I'm pretty sure you need aftermarket lugs... don't use stock lugs if it doesn't seat properly.. dangerous.
  3. Oct 16, 2016 at 6:53 AM
    thoj
    thoj New Member
    2015 black tundra SR5 crewmax 4x4
    Use aftermarket lugs with a tapered ends or you might get vibrations in the wheel and steering wheel. The stock lugs do not catch enough threads and is dangerous.
    NewImprovedRon likes this.
