Will my rear end sag on a 2.5 gen 2019 Tundra with 300lb. tongue wt.
Discussion in 'Towing & Hauling' started by IowaGuy, Oct 15, 2021.
  1. Oct 15, 2021 at 11:03 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am getting ready to purchase a 2019 Tundra SR5 Upgrade pkg. and will be pulling a 3000lb enclosed toy hauler that I am converting to just a camper. The tongue weight is approx. 300 lbs and I dont have more than 4000lbs total with gear and equipment. Will the rear end sag on a 2019 Tundra? Are the TRD offroad models any different for springs or tow capacity? Will I need helper springs, sumo springs or timbrens to stop sagging? I am not worried about a little sag but I just don't want it to be like a Dodge Ram 1500 pulling a 38 ft travel trailer.
    Oh, my toy hauler is a 17ft Charmac, again it is just for camping and no toys in it.
  2. Oct 15, 2021 at 11:05 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    It will definitely sag a little with 300 pound tongue weight (3k to 4K trailer) but it shouldn’t be enough to require a suspension aid IMHO. However a suspension aid wouldn’t hurt and typically allows the stock suspension to last a little longer.
  3. Oct 17, 2021 at 6:00 AM
    Retired...finally
    It seems trailers are designed to err on the high side of tongue weights. 300 pounds will only drop you a small amout. Just WAG but 1/2" might be close. If your 4,000# trailer is like most expect closer to a 500# tongue weight. I'm betting I'm between 550 and 600# with a 5400# loaded trailer and use a WDH. Wouldn't leave home without it.
  4. Oct 17, 2021 at 7:05 AM
    AZBoatHauler
    So.Arizona
    Have two normal sized friends sit on the tailgate. There is your answer.
    Hbjeff, 15whtrd, FireArrow and 2 others like this.
  5. Oct 17, 2021 at 7:23 AM
    IowaGuy
    In Process
    How about my wife
    Dr Doobie, Shamrock92, Azblue and 2 others like this.
  6. Oct 17, 2021 at 7:35 AM
    AZBoatHauler
    So.Arizona
    Being in Iowa, that may be too much.
    :boink:
    j/k :fistbump:
    Dr Doobie, Hbjeff, Azblue and 2 others like this.
  7. Oct 18, 2021 at 11:01 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    My travel trailer has about 450-500lb hitch weight and with the bed almost empty it still has some rake.
    I later added blue SumoSprings to help support the load when I’m at max and they work as advertised though if you go that route I’d recommend ordering a set of 7.75” long U Bolts and replacing the stocks.
  8. Oct 18, 2021 at 3:40 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    For reference, this is with about 750 lbs of tongue weight. The WDH was installed in this pic, but not adjusted yet. I'd say I have a good 3-4" of sag with it, so for 300 lbs, you'd probably be looking at around an inch, maybe a tad more.
    IowaGuy[OP] likes this.
  9. Oct 18, 2021 at 3:45 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Open your tailgate measure from ground, then you and ur wife sit on the tailgate and measure again, that’s how much sag you’ll have
  10. Oct 18, 2021 at 3:52 PM
    AZBoatHauler
    So.Arizona
  11. Oct 18, 2021 at 4:19 PM
    Once your WDH is set up properly, you should have no more than a 1 inch drop.
    JDR76[QUOTED] likes this.
  12. Oct 18, 2021 at 4:22 PM
    JDR76
    JDR76 New Member
    WA
    Yeah, it's much better with the WDH set up. This photo was right after I got the truck and was just getting ready to dial it in.
    Tundra234[QUOTED] likes this.
  13. Oct 18, 2021 at 4:23 PM
    Yeah they really are nice. I had a 3 to 4 inch drop before I put mine on.
  14. Oct 18, 2021 at 4:26 PM
    Retired...finally
    What the heck were you towing? The Space Shuttle?o_O
  15. Oct 18, 2021 at 4:33 PM
    21 foot travel trailer that's about 4K. The next time I hook up to it I'll take pics and measurements of before and after the WDH is hooked up.
