Will LT275/65r20 paired with 20x9 work with my setup?
Discussion in 'Wheels & Tires' started by luis973, Feb 10, 2017.
  1. Feb 10, 2017 at 1:47 PM
    luis973
    luis973 [OP] New Member
    Considering throwing a set of LT275/65r20 paired with 20x9's with a -24 offset, will this work without chopping the body mount on a 2014 Tundra trd offroad with a Toytech 3/1 level?
    Cue_32 likes this.
  2. Feb 10, 2017 at 3:07 PM
    Slimwood Shady
    Slimwood Shady New Member
    Linwood
    San Antonio, TX
    ‘23 TRD Pro, 996 Turbo
    I have this exact tire setup with my Fuel Trophy's with an offset of +20. I rub the front bumper slightly with only a 1.9" 6112 lift in the front. I am told to just move the plastic forward, but am not able to find what the hell anyone is talking about...
  3. Mar 14, 2017 at 8:05 AM
    Adarcy
    Adarcy New Member
    Andy
    2015 Tundra LTD CM 4x4
    Bilstein 5100's (middle), ESP Storage + Trailer Brake Mount, CB +2 Shackles, BFG AT KO2 275/65r20
    @Slimwood Shady Can you post a picture of your truck? I'm having 275/65r20's and Bixstein's put on today and am still torn between the 1.75" or 2.25" lift settings...
  4. Mar 14, 2017 at 8:14 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Here you go buddie. This should give you a rough idea on how it is done.
    Post#45
    https://www.tundras.com/threads/bluebottles-16-plat-cm-build.7379/page-2#post-115887
  5. Mar 14, 2017 at 8:17 AM
    chphilo
    chphilo Tundra addict
    Western PA
    With -24? I think you are gonna have to do some serious cutting.
    easleycrawler likes this.
  6. Mar 14, 2017 at 8:22 AM
    Adarcy
    Adarcy New Member
    Andy
    I'm on stock 20" limited wheels
  7. Mar 14, 2017 at 2:52 PM
    Adarcy
    Adarcy New Member
    Andy
    Got the tires on. Fit great and no rubbing. I'll snap some better pics tomorrow.
    Went with the Bilstein 5100's on the middle setting with one coach builder shim on the left side.
    Coach builder +2 shackles in the back.
    275/65r20 BFG All Terrains in limited wheels.
    One before photo in there as well.
    Andy
    Samoan Thor and TundraDude18 like this.
  8. Feb 4, 2019 at 7:15 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    About to get some Bilstein B8 5100’s installed 2.5” setting front only. What tire size will I be able to do? My current set up is T285/55/20.
  9. Feb 5, 2019 at 1:34 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    What wheel offset? 2.5” in front only will leave you nose high. I did 285/65/20 with a 3” lift on +18’s.
  10. Feb 5, 2019 at 3:17 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @LT75 ive ready thru here that my offset is +50...I’m not sure if that’s accurate. And I’m only 2.2/2.5 inches high on back area.
  11. Feb 5, 2019 at 4:32 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It all depends on the truck. Usually you stay at the low setting to level with nothing in back. Anything 2” or above is nose high territory. I originally had a 3/1 and I was nose high. You should be fine with 275/60/20’s.
  12. Feb 5, 2019 at 5:05 PM
    2016 sun bro mic
    2016 sun bro mic New Member
    Nelson
    Conover NC
    2016 sunset bronze mica tundra
    Front leveled new wheels and tires
    2.5 level in front only 275/60/20 on 20x9 with +20 offset
    mattyd170 likes this.
  13. Feb 5, 2019 at 6:39 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    That’s like a slight difference in tire size no? Coming from what i already have 285/55/20...wonder if it would be worth making the change?
  14. Feb 5, 2019 at 7:39 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Love it, looks good. Can you do a full side shot too. Thanks.
    KELZ84 likes this.
  15. Feb 6, 2019 at 11:43 AM
    2016 sun bro mic
    Nelson
    Conover NC
    Sorry out of town for a while with work I will when I get back thanks
  16. Feb 2, 2023 at 6:14 AM
    AdamDevoeJ
    AdamDevoeJ New Member
    2018 Silver Tundra CrewMax 1794 4WD
    Tinted windows. Upgraded LED lighting.
    Getting 275/65/20 Toyo Open Country R/T Trails with a 3”/2” supreme leveling kit on mine right now (2018 crewmax 1794).
  17. Feb 2, 2023 at 6:42 AM
    mattyd170
    Albuquerque, NM
    I will be super curious to see how this turns out. I bought TRD PRO Bilsteins for the front and a coachbuilder shim for each side, but I haven't installed them yet. I also just bought 275/65R20 tires from EBAY. Such a good deal, I couldn't pass them up. Took initial pictures yesterday and measurements. The front is exactly 2.25 inches lower than the rear on the driver's side and 2 inches on the passenger so that it may do shocks only. But don't want to go back and have to add the shims. My schedule is kind of demanding. I'll post before and after pictures once the suspension is on and then when I get the tires on.
  18. Feb 2, 2023 at 1:10 PM
    AdamDevoeJ
    Here she is with 3” in the front 2” in the back and on 275/65/20 Toyo Open Country R/T Trails.
    Extremely impressed with how it turned out!
  19. Feb 2, 2023 at 1:16 PM
    mattyd170
    Albuquerque, NM
    Very nice. 3" in the front and 2" in the back gives it a slight rake still? Looks good, liking the size. I'm gonna try to get mine done now in the next few weeks. Shall see.
  20. Feb 2, 2023 at 1:22 PM
    AdamDevoeJ
    Yes. There is a slight rake however it still looks and drives incredible.
    Very pleased with this setup.
    My father has a 2014 SR5 and went with the 285/55/18 BFG KO2’s and those look great with stock suspension as well!
  21. Feb 2, 2023 at 1:26 PM
    Toyotaguy1654
    Toyotaguy1654 New Member
    2018 Tundra 5.7L
    Awesome awesome truck.
  22. Feb 2, 2023 at 1:27 PM
    Toyotaguy1654
    2018 Tundra 5.7L
  23. Feb 2, 2023 at 1:33 PM
    AdamDevoeJ
    Yeah. I’ll take one and post soon.
  24. Feb 2, 2023 at 3:08 PM
    AdamDevoeJ
  25. Feb 2, 2023 at 4:08 PM
    Toyotaguy1654
    2018 Tundra 5.7L
  26. Feb 12, 2023 at 2:25 PM
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    275/65/20 Cooper ATP II’s. 5100’s set on the middle setting.
    Cue_32 and mattyd170 like this.
  27. Feb 12, 2023 at 2:45 PM
    AdamDevoeJ
    man.. that’s a nice color
    AGSport[QUOTED] likes this.
  28. Feb 20, 2023 at 4:19 AM
    AdamDevoeJ
    Well.. this happened over the weekend.
