Will lifting my truck effect recall?
Discussion in 'General Tundra Discussion' started by cementsharktrd, Feb 22, 2022.
  1. Feb 22, 2022 at 11:04 PM
    cementsharktrd
    cementsharktrd [OP] New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    I just got a recall notice in the mail about my steering hardware and the popping has been happening recently, even if my truck is lifted will they still fulfill the recall?
  2. Feb 22, 2022 at 11:38 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    As long as your steering rack is still OEM i’m pretty confident they won’t deny your recall service.
  3. Feb 23, 2022 at 12:02 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If your rack was defective they should replace it. The lift didn’t cause the manufacturing defect. Now a dealer could deny warranty work for a rack if used on a tall lift
  4. Feb 23, 2022 at 3:10 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    I replied to your comment on the power steering recall thread.
    If your rack is has the dimple in the B pie piece, it needs to be replaced under the recall. However, they may charge you if your lift adds time or costs to the repairs. For example, 3rd brake light fails (not the bulb) and Toyota says they will cover it under warranty, but you have a cap on it. Toyota may charge you to remove and reinstall the cap so they can access the 3rd brake light.
    Orracle likes this.
