Will I need an audio converter
Discussion in 'Audio & Video' started by TRDProLife, Jul 18, 2021.
  1. Jul 18, 2021 at 6:20 AM
    TRDProLife
    TRDProLife [OP] LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    So I am about to set up a single Amp and subwoofer. Ibwill be keeping the stock head unit. Will I need an audio converter like the lc2i? Or are there other more affordable options? Or do I not need it at all?
  2. Jul 18, 2021 at 6:24 AM
    TRDProLife
    St.Louis
  3. Jul 18, 2021 at 6:25 AM
    seniao
    seniao New Member
    Santi
    Buford, GA
    2019 Silver Sky Metallic SR5 Double Cab
    TRD Pro Head Lamps Spray Bed Liner Side steps Peragon Tonneau cover
    That’s really expensive. You can just use this one from Amazon.
    Car Stereo Audio Speak Signal Hi-Low Converter for Auto Amp Subwoofer Amplifier CD Player High to Low Adapter https://www.amazon.com/dp/B07S8W7BRQ?_encoding=UTF8
    also If your amp has the feature on it, you can just tap into speakers as some amps have a line out on them directly.
    edit. Just looked up the Rockville dB13 amp. It absolutely needs an loc.
