Will further damage occur from noisy pinion bearing.
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Feb 6, 2020.
  1. Feb 6, 2020 at 5:39 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Hello, earlier today i posted a question in regards to my noisy pinion bearing. I didnt word it the way i should have. Will my noisy pinion bearing cause any damage to the rest of my differential system? My mechanic says no. Just thought id ask you guys.. I'm confident it will last for at least a couple more years if i let it be, but i just want to clarify that question. I dont think it will since not much metal will be actually shaving off from the pinion bearing. Just want to hear some opinions from my fellow 1st gen owners
  2. Feb 6, 2020 at 6:13 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    The pinion bearing also is shimmed to set pinion gear depth which is part of the gear mesh with the ring gear. So if the bearing wore enough to allow the pinion gear to move/wobble enough it will damage the ring gear also.
    Plus, has the differential fluid been checked for proper level, contamination and proper fluid type to make sure it didn't contribute to the bearing failure?
  3. Feb 7, 2020 at 5:20 AM
    Pucks18
    @PCJ yes. 2 months ago i heard the noise and did a drain and refill with 75w90 cause i suspected the rear diff making the noise. 3 days ago i took it to the mechanic and they said it was the pinion bearing, they also said the 75 weight i put in is not the factory specs, so i drained and refilled again yesterday with 80w90.
  4. Feb 7, 2020 at 5:27 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    It wont damage the rest, not if it's just a whine. Not sure how they are set up, but usually there are shims on a differential for the side bearings. The pinion uses a crush sleeve and can only be used once. Even I as a master tech I wont bother rebuilding one, when you can just find a better rear end.
  5. Feb 7, 2020 at 6:04 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If pinion bearing failure has begun (rumbling, not whine), two years additional life is very optimistic in my opinion. Remaining life may be limited to weeks or months. Metal is not shaved off failing bearings...bearings fail from metal spalling off the rolling elements and races, with the metallic debris inside the bearing accelerating the process.
    @zombie may have the best plan: Drive to destruction, or until noise is unbearable (whichever comes first), then replace with a used differential.
  6. Feb 7, 2020 at 7:42 AM
    Pucks18
    @zombie Okay thanks. So eventually whenever i feel like fixing the noise i should just buy a whole new/used differential housing pretty much? Ill get to that next year probably.
  7. Feb 7, 2020 at 10:32 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Crush sleeve sets bearing preload/rolling torque not pinion gear depth. Shims under pinion bearing set pinion depth and the carrier side bearing shims set ring gear position and carrier bearing preload.
    Pucks18[OP] and Vizsla like this.
  8. Feb 7, 2020 at 1:00 PM
    Pucks18
    @JohnLakeman thanks for the clarification between a failing one and a noisy one. Mine is just whining at this point, so I'm good to go for a little while longer
    JohnLakeman likes this.
  9. Feb 7, 2020 at 5:22 PM
    JohnLakeman
    Sorry for misinterpreting the problem. I believe the whine may actually be from out-of-spec gear contact, which can result from normal pinion bearing wear as the techs have said. Bearings that are making noise are well down a short failure road. Best of luck.
  10. Feb 8, 2020 at 3:26 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I never said anything about the sleeve setting pinion depth.
  11. Feb 8, 2020 at 3:32 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    So if it's just a whine, that's all it is, there will be no shavings unless it starts to grind. For example, I have changed thousand of wheel bearing in my time. Just for a whining noise, and when you remove it it looks just fine. Imports mostly. Chevy will go from a whine to a grind very quickly.
  12. Feb 8, 2020 at 3:37 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I also just gave minor info on what's in the rear end to defer you from trying to fix it. So as you can see it's a complicated thing.
  13. Feb 8, 2020 at 7:15 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Must have misunderstood what you wrote. My apologies.
  14. Feb 10, 2020 at 3:18 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    It's all good. :thumbsup:
