Will BD tuner fix the dreaded 5.7 ffv ethanol/gas issue
Discussion in 'Performance and Tuning' started by ZooMoto, Feb 25, 2021.
  1. Feb 25, 2021 at 5:51 AM
    ZooMoto
    ZooMoto [OP] New Member
    Mack
    2015 Tundra 5.7 FFV
    Hey guys and gals,
    Long time creeper, first time poster.
    2015 Tundra with 5.7 ffv just went out of warranty and am now dealing with the dreaded rough start, running rich issues that seem to plague these trucks.
    Going to the dealer on Monday to get a diagnostic and expecting to be told that the fuel pump, etc needs to be replaced.
    My question is will running a new tuner from bully dog allow me to lock out of ethanol mode for good and bypass the $2000 service from the dealer?
    Would be thankful for any help. I rebuild vintage Jap bikes and have always owned older vehicles prior to this purchase. I can tune carbs all day but all this mystical technology stuff is new for me.
  2. Feb 25, 2021 at 6:18 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Subscribed.
  3. Mar 8, 2021 at 1:21 PM
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    I can't imagine it would due to the alc % and engine response being computed by ECU from expected fuel input and o2 sensors. I'm in the same boat and thought of the same potential workaround.
    I've read others have put aftermarket fuel pumps on and had success (URD was mentioned as one source, though their site says pumps for the tundra will not work with flex fuel engines, so I'm lost how that's a solution). After 3 trips to dealer, I finally printed out the TSB, highlighted the sections that applied and what I wanted them to do to reset the ecu (no fuel pump replacement due to their absurd labor/markup). Cost $150, but I still have the delayed coughing start and stuttering through 1st gear from stop, and ethanol reading 85%. So they either 1. didnt' do anything and charged me because I was frustrated and brought them instructions 2. did the reflash, but not the alcohol density relearning or 3. did the reflash and relearning, but I won't see a change until the pump is replaced.
    Any of you vets who have had extended success after addressing this issue want to share some knowledge?
  4. Mar 8, 2021 at 1:35 PM
    TXTundra2722
    2015 Black Tundra
    I kinda second what this guy said...$2,000 dollars for a full pump service is ridiculous when you can do it yourself for a fraction. Plenty of YouTube videos on this as well for assistance.
  5. Mar 9, 2021 at 10:59 AM
    dirtydeeds
    Keith
    USA
    Give Keith Carty of Dirty Deeds Industries a call at 760-877-4234 and pick his brain on this. Bully Dog and Keith did a ton of testing and product development over the years together.
    WILLINH and ZooMoto[OP] like this.
  6. Mar 9, 2021 at 4:30 PM
    ZooMoto
    Mack
    2015 Tundra 5.7 FFV
    Alright, guys...
    Just got back from the dealer. Truck seemed more responsive when i picked it up. It was running when they handed it off to me. Drove back to work and parked it for 5ish hours in 60 degree weather and hard the exact same issue. Nothing like $1200 down the drain.
    Invoice states EN001 Reprogram and R&R Fuel pump, 77020-0C120 tube assy fuel suct, and 77169-0C010 Gasket.
    $661.73 in parts and 494.76 in labor.
    Back to the drawing board.
  7. May 24, 2021 at 3:59 PM
    fytedapowr
    Jake
    Austin TX
    '15 1794 4x4
    did you check under the hood to see if they put a sticker to show the new ECU updated version? The TSB says to replace fuel pump, flash ECU, then relearn alcohol readings. Very possible one of those were not done. I'm fairly positive the last time I asked them to flash my ecu I was charged but no work was done. I haven't seen anyone here who has had the problem continue after finding a dealer who agreed to do the TSB.
  8. Jul 25, 2021 at 9:58 AM
    fish2keel
    fish2keel New Member
    Does any one have a link to the tsb?
  9. Jul 26, 2021 at 9:02 AM
    fytedapowr
    Jake
    Austin TX
    '15 1794 4x4
  10. Dec 25, 2021 at 10:37 PM
    Dupey
    Dupey I love chips and salsa!
    Northern Colorado
    2014 tundra platinum
    TRD PRO GRILL TRD PRO HEADLIGHTS W/I hacker ADAPTER WIRING WEATHER TECH FLOOR LINERS C4 FRONT BUMPER WITH 30 inch LIGHT BAR RCI ROCK SLIDERS RCI SKID PLATE RCI LOW PROFILE BED RACK ARB TOURING ROOF TOP TENT TOYTECH 2.0 FRONT COILOVERS TOYTECH REAR SHOCKS TOYTECH 1.75 SHACKLES
    I know this thread is old but I went in to my dealership and they new exactly what the problem was and told me about the tsb. I asked them to do the ECU flash and Ethanol relearn and they are happy to do it as long as I understood that it may only be a temporary fix and I might need the fuel pump in the future per tsb recommendation. It’s only been a couple days but I’m getting 13 mpg again Instead of 7 and the rough cold start also went away for now.
    Metro14536 and fytedapowr like this.
  11. Jan 11, 2022 at 8:18 PM
    jason......
    jason...... New Member
    does anyone know what is different about the replacement fuel pump, vs. the original one?
  12. Jan 12, 2022 at 10:41 AM
    fytedapowr
    Jake
    Austin TX
    '15 1794 4x4
    Far as I could tell when I went down this rabbit hole, they are the same. The impellors have issues on some fuel pumps, so they replace with the same and hope it doesn't. I have the delphi part number on my DIY replacement post and that's why I went aftermarket and don't regret it
    jason......[QUOTED] likes this.
  13. Jan 12, 2022 at 10:48 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It does not allow any pick & choose modes outside performance, shifting etc. Furthermore, it threw codes all the time on my Flex Fuel 2013 Sequoia that they say is compatible but for 9 months have not provided a solution. I have mine for sale unlocked here if you want to try.
    My full disclosure warning is their support stinks and it did not work on my Sequoia but did on my non Flex 2010 Tundra.
    jason...... likes this.
  14. Dec 24, 2023 at 12:35 PM
    Robthecloud21
    Robthecloud21 New Member
    Ontario
    2015 Tundra TRD Pro
    I’m not sure if anybody on here is familiar with YotaTune. I live in Ontario, not sure if they do American visits or not. But I recently purchased an American 2015 pro with this issue. Anyway, YotaTune did the alcohol reset and an ECM update for $90 CAD. The tuner was unsure of whether or not the problem would return but it’s been almost 3 months without a hitch. At the very least you could get the alcohol reset done for a more reasonable price than at the dealers. I contacted my local dealer when I learned about this issue and they apparently had no idea what I was talking about as flex fuel tundras are very rare in Canada.
  15. Dec 24, 2023 at 1:19 PM
    e30cabrio
    BD barely (IMHO) does what it's marketed to do. I use Techstream to reset my ethenol when I need to.
    Oops. I thought this was a new thread.
    Lol
  16. Feb 2, 2024 at 7:10 PM
    Jonpg37
    Jonpg37 New Member
    2015 tundra pro inferno
    Can anyone in Houston reset my ethanol/alcohol $$$ .trk just started to have hard start after the cold weather we had
  17. Feb 5, 2024 at 10:34 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I can in Lago Vista, bout 3hrs from Houston.
  18. Feb 5, 2024 at 12:24 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Pump replacement not really required in most cases I think.
    From TSB, these steps work.
    1. Perform the learning value reset
    2. Perform the fuel density learning value reset. Then key off.
    Additional steps some people skip...
    3. Add 3 gallons gas.
    4. Test drive. I think at least some miles is best but just my opinion.
    I think 3 & 4 may be important. I used Scangage to watch my fuel trims and alcohol % after the resets. Adding fuel seems to trigger something for alcohol value. That number took some time to stabilize but has stayed at zero now since the 3rd or 4th fill up.
    https://www.tundras.com/threads/res...ge-level-with-bidirectional-scan-tool.123799/
    Tundrarayray86 and Ebrperk like this.
  19. Jan 4, 2025 at 5:01 PM
    Tundrarayray86
    Tundrarayray86 New Member
    Ray
    4x4 2012 5.7FFV Tundra Sr5
    3in lift
    I'm in a similar situation 2012 with 125k miles FFV going off of the Toyota carcarenut channel there's definitely a specific procedure and should be switching around fuel types on the fly. Currently running rich on startup but then goes away. When I first bought the Tundra I went ahead and paid about 390 at the Toyota network dealership for a ECU reset just to be sure but I'm gonna have to go elsewhere because they don't even do TSB work.
