Will a 600 watt amp be enough?
Discussion in 'Audio & Video' started by SpencerR, Nov 22, 2018.
  1. Nov 22, 2018 at 9:25 AM
    SpencerR
    SpencerR [OP] New Member
    Hey guys, getting an upgrade and here is what I am going with:
    RF 6x9 in front doors
    RF 6.5 in rear doors
    JL Audio 10W0v3-4 (x2)
    2x10" Box from Fox acoustics
    2011 Toyota Tundra CrewMax
    My question is, can a 600 watt 5 channel amp power all this or should I look at going with a 1000 watt amp? Thanks!
    And also, amp recommendations are appreciated!
    trdprobped17 likes this.
  2. Nov 22, 2018 at 9:26 AM
    Rica25
    Ricardo
    Tulare
    Look at RMS and NOT......max wattage
  3. Nov 22, 2018 at 9:27 AM
    SpencerR
    I still don't fully understand the difference. The watt rating for the subs is 75-300
  4. Nov 22, 2018 at 9:30 AM
    Rica25
    Ricardo
    Tulare
    RMS is true power........so example my sub has max handle 1100 watts but the RMS is 750 .......so the amp I purchased is 1500 watt max but the RMS that is true power is 900 at 2 ohms......to make sure I can power it enough
    Ra1dercak3 likes this.
  5. Nov 22, 2018 at 9:32 AM
    SpencerR
    So if I have 2 subs with an RMS of 75-300 each, as well as door speakers I am wanting to run off the new amp, I should probably go with a 1000 watt amp? Obviously I wont be running both subs at 300 RMS though, so maybe 600 would be fine?
  6. Nov 22, 2018 at 9:36 AM
    Rica25
    Ricardo
    Tulare
    It is always better to over power by a bit then to under power a sub...............watch some YouTube videos and you can learn quite a bit I watched some before putting mine together
  7. Nov 22, 2018 at 9:37 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    1000 watt RMS amp, if your 6.5 and 6x9 all draw 75 rms, thats 300 watts, then 300 per sub you are at 900 watts rms.
  8. Nov 22, 2018 at 11:48 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  9. Nov 22, 2018 at 12:20 PM
    SpencerR
    I was looking at the rockford fosgate 5 channel 1000w amp. I think the 1000x5
    smslavin likes this.
  10. Nov 22, 2018 at 1:28 PM
    Danimal86
    Daniel
    Sacramento, CA
    Find something that's 50-75rms x 4 + 500rms x1
    stevep1794 likes this.
  11. Nov 22, 2018 at 1:31 PM
    SpencerR
    what about a 4 channel for the speakers and a 500w mono for subs?
    Mountun Goat and Larmand like this.
  12. Nov 22, 2018 at 1:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    That'll work too! You just have to get a distribution block to split the power wire coming from the battery.
  13. Nov 22, 2018 at 1:35 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    This is probably the best route to go.
  14. Nov 22, 2018 at 4:15 PM
    trdprobped17
    trdprobped17 New Member
  15. Nov 22, 2018 at 5:44 PM
    SpencerR
    Mountun Goat likes this.
  16. Nov 22, 2018 at 7:11 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Should work. You’ll want to pair the sub and the box for air volume as well. The sub will have Ported or sealed box size notes. Try to fit in that volume for best performance. A lot going on with stereos
  17. Nov 22, 2018 at 7:12 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    In all honesty if your a noob and have cash to spend bring it to an audio shop and say this is what I’m willing to spend. They will give you your best bang for buck and a good setup tuned correctly. My 2 cents
  18. Nov 22, 2018 at 7:17 PM
    Rica25
    Ricardo
    Tulare
  19. Nov 22, 2018 at 7:19 PM
    Rica25
    Ricardo
    Tulare
    That box looks good enough for the ported bart it show 2.2 cubic feet of air space and the subs show max size of 1.25 cubic per sub
  20. Nov 22, 2018 at 7:23 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Too much beer to read all this. What amp exactly are you looking at? Need to know the per channel split. Sounds low for 2 10s.
  21. Nov 22, 2018 at 7:25 PM
    Rica25
    Ricardo
    Tulare
    Are you looking for big bass or something little better than stock
  22. Nov 22, 2018 at 8:23 PM
    SpencerR
    Okay cool so that sounds like it should be fine
    I was comparing the RF 600 watt 5 channel and their 1000w 5 channel. I’m now also looking at the pioneer 5 channel that does 75x4 and 600x1
    My stock is absolute piss so I’m looking for far superior to stock. I listen to a lot of metal so for me it’s all about the drums and crisp vocals/guitars
    Rica25[QUOTED] likes this.
  23. Nov 22, 2018 at 8:27 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The 1000 watt one, 100w x4 and 600w x1 should be good. 600 watts split for 2 subs will go well.
    I've been eyeballing that same amp for when I scrap my system and start over.
    Rica25 likes this.
  24. Nov 22, 2018 at 9:01 PM
    SpencerR
    The RF 1000x5 is 500x1 at 1 ohm. The pioneer is 600x1 at 2 ohm
  25. Nov 22, 2018 at 10:00 PM
    Danimal86
    Daniel
    Sacramento, CA
    The pioneer is hard to beat for the price.....Watch this to see what the real output is
    Rica25 likes this.
  26. Nov 22, 2018 at 10:01 PM
    Rica25
    Ricardo
    Tulare
    This guy makes good reviews
  27. Nov 22, 2018 at 10:01 PM
    Rica25
    Ricardo
    Tulare
    I bought the Audiopipe he reviewed very cheap in price and he has good comments on it
  28. Dec 5, 2018 at 9:28 AM
    Tifany2017
    Tifany2017 New Member
    Jay
    2017 Tundra TRDpro Cement DC
    Gizmo antenna decor
    Am I the only one that looks at the fuses in the amp and adds them together and multiplies it buy the battery output voltage to get my watts?
    If a amplifier only has one 25amp fuse its not going to put out no where near 1000 watts.
  29. Dec 5, 2018 at 10:23 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i have this amp. it's 125 x 4 and 500 x 1. so you get 125w for each of the doors and 500 into the sub. i'm only running a single 12" though.
  30. Dec 24, 2018 at 10:24 AM
    Ra1dercak3
    Ra1dercak3 New Member
    Derek
    2018 Tundra XP
    I am a Hertz audio guy. Sometimes total RMS isn't a factor in comparison to clarity. Just my opinion .
