Will a 33" diameter tire fit in the spare tire slot?
Discussion in 'Wheels & Tires' started by MR TRD PRO, Jul 7, 2019.
  1. Jul 7, 2019 at 2:10 PM
    MR TRD PRO
    MR TRD PRO [OP] New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    Hello all,
    I was thinking of upgrading o a 33" diameter BFG K02 tire on the stock spare tire wheel. Will it fit underneath?
  2. Jul 7, 2019 at 3:01 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    When I was under my truck replacing the exhaust I had to lower the spare and realized that their are small brackets that might have to be bent back in order to fit a bigger tire. A 33 is only .5" taller than stock if I'm not mistaken. Looks like a small modification but, I think it should be possible. If you were going any larger than it might not work. I'm in the same boat. I went up to 275/70r18 but, still need to change out my spare to the same size. Someone who has done this might chime in.
    CaptSpaulding likes this.
  3. Jul 7, 2019 at 3:05 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Currently running a 295/70r18 (34.3") underneath with zero modifications. My exhaust dumps before the rear axle though. Bend the hanger tabs and I believe you can fit a 35"
    MR TRD PRO[OP], Mr Swervlin and Pinay like this.
  4. Jul 7, 2019 at 3:24 PM
    Justin Case
    Justin Case New Member
    TX
  5. Jul 7, 2019 at 3:29 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    My 285/75/17 (33.8") barely fits.
  6. Jul 7, 2019 at 4:07 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    The short answer, as mentioned above, is yes.
    I have a 275/70R 18 KO2 mounted under my truck without any modification whatsoever.
    As mentioned, there are a couple of metal tabs and I think the tire would fit better if you were to either bend or remove them, but it isn't necessary.
    Mr Swervlin and MR TRD PRO[OP] like this.
  7. Jul 7, 2019 at 4:24 PM
    MR TRD PRO
    Queens, NYC
    HP Tuned
    Thanks everyone for your input and for helping a newbie out
    CaptSpaulding and Mr Swervlin like this.
  8. Jul 7, 2019 at 5:32 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Yes there's a few posts on it, have to bend a bracket out of the way.
  9. Jul 7, 2019 at 6:50 PM
    Rubberdown
    You can throw a 315/70/17 (34.5) under there if your shackles bolts will clear. I had to reverse mine. Maybe I did something else... i did whatever I did 9 years ago so I can’t remember.
  10. Jul 9, 2019 at 4:57 PM
    MR TRD PRO
    Queens, NYC
    HP Tuned
    thanks guys!
