Will 37's fit?
Discussion in 'Wheels & Tires' started by Rexr, Dec 11, 2024.
  1. Dec 11, 2024 at 6:44 PM
    Rexr
    Rexr [OP] New Member
    Sam
    Bay Area, CA
    2018 SR5 CrewMax
    Corsa Sport Catback Exhaust Bilstein 6112 front coil overs + 0.5 coach builder shims Icon tubular UCA Coachbuilder extended front bumpstop Icon 1 inch diff drop Icon RXT leaf pack Icon RXT rear shocks Timbren rear bump stop Horn blasters conductors special
    Hi Everyone,
    I am currently doing a build on my 2018 SR5 Crew max and am hoping to put 37's on it. I just got suspension installed along with some cutting. I also have a bumper coming in within the next 2-3 months. I wanted to know if you guys think I could clear 37s with the following mods:
    Front suspension
    Bilstein 6112 front coilovers +2.5in lift
    Coachbuilder shims +0.5in lift
    Icon tubular UCA
    Trimming done
    Cab mount relocation kit
    Pinch weld flattening
    CBI Baja hybrid front bumper
    Wheels and tires
    Method 707 17x8.5 0mm offset
    Mickey thompson baja boss AT 37x12.5 (have not purchased yet, but have read that they measure true to being a 36 1/4)
    I know I will not have to worry about rubbing in the front, but my main worry isn't even the body mount its the fender and fender flare. Will I have to trim the fender or do you guys think it will fit with just the pinch weld being flattened?
  2. Dec 11, 2024 at 7:56 PM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
  3. Dec 12, 2024 at 5:34 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Dont forget one of the most important mods when fitting 37s.....you need to regear the truck- folks use 529s so that will add a couple grand to your plan installed.
    GODZILLA likes this.
  4. Dec 12, 2024 at 6:05 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Get the 37's, they'll look great.
    Turn the nannies off and drive in S mode or get 5.29's
