Will 315/70/18 fit without rubbing, with a 6" suspension?
Discussion in 'Wheels & Tires' started by 2015 TUNDRA LIMITED, Feb 1, 2016.
  1. Feb 1, 2016 at 9:45 PM
    2015 TUNDRA LIMITED
    2015 TUNDRA LIMITED [OP] New Member
    2015 TUNDR LIMITED TRD
    New 6" Rough Country suspension lift kit
    20160131_090531_resized.jpg Hi ,
    I just got a 6" Rough Country suspension on my Tundra i was wondering if 315/70/18 tires will fit without tire rub? The tires i have on there now are 275/70/18
  2. Feb 2, 2016 at 6:32 AM
    ToyotaTundraMike
    2015 Tundra
    315/75 is pretty close to a 35 x 12.50 right?
    Guys on here fit 35's with much less lift so I think you will be okay depending on your wheel offset. May have to do some minor mods to prevent rubbing on the inside but I'm sure some of the guys who run similar tires will chip in.
  3. Feb 21, 2016 at 3:29 AM
    Jay-U
    Jay-U New Member
    How do you like your RC lift?
  4. Feb 21, 2016 at 6:09 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    With 6" you should be fine to do 35's. All tires run different in sizes so you need to check the overall diameter of the tire you are looking at.
  5. Feb 21, 2016 at 8:16 AM
    Offset plays a role in this too...
  6. Feb 21, 2016 at 8:30 AM
    Masteryota16
    Masteryota16 New Member
    2016 Black Tundra SR5
    4" Pro Comp stage 1 35/12.50/20 Nitto Trail Grappler 20x9 Mayhem wheels
    I am running 35-12.50-20's with 4" lift no rubbing so you should be fine with 6"tundra.jpg
    T-Rex266 likes this.
