Will 295/70/18’s Hit UCA?
Discussion in 'Wheels & Tires' started by CatskillMtnCustoms, Aug 15, 2019.
  1. Aug 15, 2019 at 2:18 PM
    CatskillMtnCustoms
    CatskillMtnCustoms [OP] New Member
    Nick
    Upstate, NY
    2017 Black Tundra TRD
    3/2 Lift
    I have a 3/2 Ready Lift on my 2017. I just ordered some 295/70/18 Cooper Discoverer AT3’s to put on my stock TRD off-road wheels. I have some Spidertrax 1.25” spacers which I know will definitely provide the clearance I need. But, I wanted to bring the truck to get the tires mounted and an alignment without the spacers because I hear that some shops are refusing work with spacers. It looks like the tire would be close to the upper control arm, but it’s hard to tell. Anyone have any experience?
  2. Aug 15, 2019 at 3:54 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    I could barely squeeze my pinky between mine when I put that size on my stock TRD pro wheels, only rubbed the forward mud flap
    Black Wolf likes this.
  3. Aug 15, 2019 at 5:59 PM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Thanks. Did you have a lift installed? It seems like the 3” spacers actually put the control arm in a worse position in relation to the tire.
  4. Aug 15, 2019 at 6:16 PM
    Suspension geometry with 3" inch lift whether spacers or new coilovers would be better with aftermarket UCA's.
  5. Aug 15, 2019 at 6:26 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @CatskillMtnCustoms, with your 1 1/4" spacers you should be fine. I had that set up with no issues other than front passenger mud flap . As far as your lift, not sure. I have 6112's up front and 1" tapered block in rear.
  6. Aug 15, 2019 at 6:57 PM
    Jaywhy
    Jaywhy Old Member
    Jeff
    2016 SW TRD Pro CM
    I have a stock pro with Yokohama geolandar at in that size. It's really close, but doesn't hit. Tiny mud flap up front was the only rub issue
  7. Aug 16, 2019 at 3:20 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Absolutely, just not in the budget right now.
  8. Aug 16, 2019 at 3:23 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Thanks. I know it will definitely be fine with the spacers, but I was trying to avoid having the spacers on when bringing the truck to have the tires installed.
    rons23[QUOTED] likes this.
  9. Aug 16, 2019 at 3:25 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Awesome thanks guys.
    Rica25 and (deleted member) like this.
  10. Aug 16, 2019 at 5:03 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes. As the suspension pivots down it is pulling the tire towards the center of the truck. When it flattens out it is pushing the tire outwards.
  11. Aug 16, 2019 at 6:29 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Yeah, and I think 3” spacers are really pushing it with stock components. I got mine for $30 from a coworker, and installed them a week ago. I don’t like how maxed out everything seems just sitting on the ground. I’m considering switching to Bilstein 5100’s, obviously a better product and just a little less lift.
  12. Aug 16, 2019 at 6:30 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    you only need 1-2 inches for those tires to look good.
  13. Aug 16, 2019 at 6:38 AM
    MakMurph
    MakMurph I'm here
    No just a stock TRD pro
  14. Aug 20, 2019 at 9:04 AM
    DECKEDUSA
    DECKEDUSA New Member Vendor
    I am running 295/70r18 Toyo AT 2 with a 2" leveling kit on my 2017. Had to do a little bending of the metal plate up front, but minimal. ZERO rubbing anytime.
    Jmad1997 likes this.
  15. Aug 20, 2019 at 6:21 PM
    MGM
    MGM New Member
    Waiting for 285/70/18 from Falken so I don’t have to worry about this. 295 look great but too much hassle for me.
  16. Aug 20, 2019 at 6:37 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Same here, i went to 285/70/18. You said it too much hassle. Went on the safe route.
  17. Aug 25, 2019 at 5:32 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Thanks for everyone’s responses. I ended up taking out the 3” spacers and installing Bilstein 5100’s (2.5”). I think the ready lift spacers are too much without swapping UCA’s. The 5100’s are just a better choice. The UCA’s are now in a much better position and I’ll have plenty of tire clearance there. My 295/70/18 Cooper Discoverer AT3’s get installed tomorrow. I also picked up a set of spidertrax spacers to help the stance just a bit.
  18. Jan 29, 2020 at 5:36 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    what was the verdict...were the spacers just to improve the stance and look...or were they required to fit the tire in (no UCA rub)?
  19. Jan 29, 2020 at 6:01 PM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    The tires ended up fitting without the wheel spacers, which I like. I prefer the tires to sit flush with the fenders. There’s about 5/8” of space between tire and UCA. I think that if I had kept the 3” lift the tires would have rubbed because it raised the UCA angle to right where the tire bulge is.
    Not a great picture, but shows the fitment.
    Tundraman479 and Iowa12tundra like this.
  20. Jan 29, 2020 at 6:10 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Good looking truck. I’m going for that same look, flush fit. I’m thinking about Toyo AT2s on stock TRD wheels with a 2” level kit.
  21. Jan 29, 2020 at 6:49 PM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Nice, I don’t think you’ll have any fit/rub issues with a 2”. Mine only needed a little trim on the skid plate for full-lock, no other rubbing.
  22. Jan 29, 2020 at 7:56 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    Do you think the 295's would have fit with only a 2" lift up front? Do you have any lift in the rear?
  23. Jan 30, 2020 at 2:27 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    I think so. The 5100’s I have are only around 2.25” so not a big difference. I have 2” ready-lift blocks in the rear. If you haven’t bought a kit already, I highly recommend getting 5100’s for the front. A much better product for the money, especially if you get them on sale somewhere.
  24. Jan 30, 2020 at 4:06 AM
    Mdjamesd
    Mdjamesd New Member
    I bought the 6112 and 5160 a year or so ago. Unfortunately, I've only installed the 5160 so far, waiting on the front until I need new tires
  25. Jan 30, 2020 at 4:44 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Cool, you should be good to go.
  26. Jan 30, 2020 at 6:50 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Installed some Toyo AT2 295/70/18 on stock rims with only a 2" level kit on my 2018. It fit no problem at all. Plenty of room between tire and UCA.IMG_20200130_172131.jpg IMG_20200130_184150.jpg
    Iowa12tundra, Big J and PermaFrostTRD like this.
  27. Jan 31, 2020 at 2:40 AM
    CatskillMtnCustoms
    Nick
    Upstate, NY
    3/2 Lift
    Nice truck. It’s funny, I was concerned because I read so many posts on here about guys struggling to fit 295’s, but you really don’t need much to run them without issue.
    Mdjamesd and Iowa12tundra like this.
  28. Jan 31, 2020 at 5:27 AM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Yep, so many conflicting threads. I feel like the official wheel and tire size thread should be updated.
  29. Jan 31, 2020 at 12:59 PM
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    @kaymonster what leveling kit did you install? By the way, you truck looks great!
  30. Jan 31, 2020 at 1:01 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Appreciate it, thanks!
    This one
    tbutler likes this.
