Will +25 offset work with my 2018?
Discussion in 'Wheels & Tires' started by blakekircher, Dec 26, 2018.
  1. Dec 26, 2018 at 2:22 PM
    blakekircher
    blakekircher [OP] New Member
    Blake
    San Diego
    2018 Tundra TRD Sport 4x4
    3” level 17x8.5 Icon Rebounds 315/70/70 Cooper Discoverer Mtps
    https://www.carid.com/method-race-wheels/305-nv-matte-black-391072135.html Hey everybody. I’ve finally decided to get some new rims and tires. as far as rims I’ve attached the link, it says it has +25 offset and I just want to make sure that is compatible with my truck. If it helps the tire size i’m planning on getting is 33/12.50/18. Suggestions for better rims accepted.
  2. Dec 26, 2018 at 2:53 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Mine are +25, pretty common offset for our trucks. I run a 33" tire with no lift.
  3. Dec 26, 2018 at 2:57 PM
    blakekircher
    Blake
    San Diego
    Do the tires stick out at all? Also do you have a leveling kit and do the tires rub at all? Thanks!
  4. Dec 26, 2018 at 5:31 PM
    RickC
    Rick
    Knoxville TN
    They stick out about an inch. I don't have any lift, it's stock. I only get rubbing when reversing in full lock. It's very little and I haven't even checked to see where it's rubbing.
  5. Dec 28, 2018 at 5:54 AM
    novae500
    novae500 New Member
    2016 Tundra DC SR5 upgraded package
    i just put 285/55/20 on Fuel that have +20 offset. Only getting some rubbing from rear driver side mudflap when full lock (steering wheel all the way cranked left). I took it off and shaved down the area that was rubbing. I'm stock, no lift.
  6. Dec 29, 2018 at 2:47 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    +25 (+ or - a couple mm's) seems to be ideal.
  7. Dec 29, 2018 at 5:10 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    +18 with 285/65/20’s on a 3/2 lift. Trimmed front well piece behind fogs. Zip tied mud flap piece down so no rubbing in reverse.
