Will 2020 Tundra wheels fit a 2009 Tundra 5 lug
Discussion in '2nd Gen Tundras (2007-2013)' started by Rhino1975, Apr 28, 2024.
  1. Apr 28, 2024 at 3:08 PM
    Rhino1975
    Rhino1975 [OP] New Member
    Jeff
    2007 Toyota Tundra SR5 Double Cab 4.0 li
    None
    Wanting to purchase a set of new Tundra Tires and Wheels off a 2020 Tundra will they fit in my 2009 Toyota Tundra SR5 Double Cab?
  2. Apr 28, 2024 at 3:11 PM
    blenton
    blenton New Member
    Yes.
    But depending on what tires you have now and what tires you get, you may need to different lugs and TPMS sensors. Usually, if you are going from an alloy wheel to an alloy wheel, you are good. If you have steelies and are going to aluminum, you would need the lugs and TPMS sensors that originally came with aluminum wheels.
  3. May 1, 2024 at 8:19 PM
    S0CKETMAN
    S0CKETMAN New Member
    07 Limited 4x4 CM Slate Metallic
    07-21 are all 5x150 bolt pattern. Tpms kits transfer over with no issues.
