Will 2019 oem wheels fit my 2012
Discussion in 'Wheels & Tires' started by Patricktatro, Apr 29, 2019.
  1. Apr 29, 2019 at 8:57 PM
    Patricktatro
    Patricktatro [OP] New Member
    Pat
    2012 tundra
    2” level
    I previously put wheels on my 2012 that came off a 2008. Center bore was slightly smaller (1mm?) and I had a horrible time getting on and off not to mention a hard time getting them on straight. (Terrible vibration at times) I want to put a 2019 oem wheel on, but don’t want to have a similar issue. Can anyone tell me if a 2019 rim will be a perfect fit or not?
  2. Apr 29, 2019 at 9:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I just put 2018 wheels on my 2010. Little tight(slight rust on the hub) but fit just fine
  3. Apr 29, 2019 at 9:14 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    No, they won’t. They’re from the future
  4. Apr 29, 2019 at 9:17 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    Who knows, Maybe they will have moved back to 6 lug by then...
    Tundra2 and Steve89gt[QUOTED] like this.
  5. Jan 2, 2021 at 9:36 AM
    jjmeyer
    jjmeyer New Member
    Josiah
    2010 Silver Toyota Tundra
    My factory rims are rusting and looking. I have a 2010 Toyota Tundra. I was in fb marketplace and found some 20” platinum oem rims (with oem lugs) from a 2018 Toyota Tundra. Do you know if these would for sure work on mine without causing any issues? I have no idea and am not very mechanically inclined and my all. Thanks for any help you could offer
  6. Jan 2, 2021 at 10:29 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes they should fit just fine. The only difference is lug nuts. OEM alloy and steel use different lug nuts so make sure you get the matching nuts for the new rims if you currently have steel
  7. Jan 2, 2021 at 10:55 AM
    jjmeyer
    jjmeyer New Member
    Josiah
    Awesome! Thanks so much! Yes, they said the matching lug nuts would come with them
