Will 2004 headlights will fit a 2005?
Discussion in '1st Gen Tundras (2000-2006)' started by arctictundra8577, Mar 30, 2019.
  1. Mar 30, 2019 at 6:07 PM
    arctictundra8577
    arctictundra8577 [OP] New Member
    Eric
    Ontario, Canada
    2005 tundra sr5
    i was looking around on ebay for a darker pair of headlights for my truck and i found a for a 2004, but i was wondering if it would fit my truck because they are the same body style.
    Liljake248 likes this.
  2. Mar 31, 2019 at 4:30 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    They will most likely fit. However, The 05-06 models have an extra bulb in the corner of the headlights, so that would be eliminated. Curious, you couldn’t find any darkish headlights specifically for the 05-06 tundra?
  3. Mar 31, 2019 at 4:59 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
  4. Mar 31, 2019 at 12:26 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
  5. Mar 31, 2019 at 2:44 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I understand. The link I provided is for the 00-04 access cab models and should fit into your truck without much hassle. I did something similar but the opposite, I put 05-06 headlights into my 2002. I’m posting 2 Ebay links so you can see the back of both the 05-06 and the 00-04 access cab lights. You will notice on the first link the bulb, socket and wire down in the corner in pic #4. That will be eliminated once you put the old style headlights in your truck. It’s not a big deal to not have it. The main big bulb/prong connection is what’s important. The second link is the 00-04 headlights.
    https://www.ebay.com/itm/Halogen-He...Tundra&hash=item3647604335:g:LtsAAOSwf75cmbUF
    https://www.ebay.com/itm/Fits-00-04...296040&hash=item544659b915:g:KdEAAOSwLpda8FaQ
    Hope this helps:thumbsup:
  6. Mar 31, 2019 at 4:26 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    Ok sounds good thanks for the help
  7. Apr 11, 2019 at 7:23 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Won't fit.
  8. Apr 11, 2019 at 7:58 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    How do you know?
  9. Apr 11, 2019 at 8:40 PM
    619Tundra
    I'm an enthusiast. The only other model that is comparable is the Sequoia. 2004 lights only fit 2004 Tundra/ Sequoia. The 05-06 Tundra changes.
    des2mtn likes this.
  10. Apr 13, 2019 at 2:59 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    I bought them, they fit, and they look awesome!
  11. Apr 13, 2019 at 5:24 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Looks great:thumbsup: I knew they would fit. Did everything plug right in? With the exception of the corner bulb?
  12. Apr 13, 2019 at 5:31 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    I there was one plug in the main headlight of the 05 that isn’t there on the 04 I don’t know what the second plug is for but I still have my high and low beams and that’s all that matters. Thanks for the help.
    revtune[QUOTED] likes this.
  13. Apr 16, 2019 at 12:39 PM
    Black Rollover
    Black Rollover New Member
    David
    2004 Tundra Double Cab Ltd
    2nd plug is probably for the Day Time running light.
  14. Apr 16, 2019 at 12:43 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    Nope I still have them
  15. Dec 6, 2019 at 9:34 AM
    itsbluenotpurple
    itsbluenotpurple New Member
    2002 Tundra AC SR5
    Better driver?
    revtune how did you put the 05-06 lights in your 02? Were you able to use the orange running light as your DTR?
    Thanks!!
  16. Dec 8, 2019 at 7:44 AM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    Can 05-06 DC's use the Sequoia "double bubble" corner lights?
    because_wumbo-truck likes this.
  17. Dec 9, 2019 at 5:03 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Yes, they will “fit” but you’ll need to make the headlight opening bigger with a metal body saw. The back of the 05-06 headlights are bigger and the corner side lights have to be paired together. In other words, buy them together. The 05-06 headlights also have a light in the inner corner with its own plug. That will need to be cut and spliced into the main headlight plug. They look good, but If I had to do it again, I would just buy the 00-04 headlights and be done.
  18. May 27, 2020 at 11:46 PM
    Liljake248
    Liljake248 New Member
    Jacob
    2004 tundra limited
    05-06 headlight conversion on an 04, lift, wheels tires, exhaust, murdered out, led fog light pods, light bar...
    19AD33BA-1E66-42AD-AFBA-122F3F0B92F5.jpg Yes the lights will fit I have a 2004 limited with the blacked out 05-06 headlights had to do some minor cutting to the radiator support to fit the lights up
  19. May 28, 2020 at 5:47 AM
    Professional Hand Model
    Hand Protectors
    You have pics of modifications to radiator support?
  20. Jun 10, 2020 at 5:18 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    i too would love to see a picture under the hood of the modification....looks like you have the smoked out 2005 lights i want on my 2004 DC. All the websites say they wont fit...but i think they will. not wanting to do too much cutting though.
  21. Jul 13, 2020 at 4:42 PM
    Bratcher1114
    Bratcher1114 New Member
    Garry
    Toyota tundra 04
    My 2004 sr5 Toyota tundra has the 05 headlights, the ones with the small light in the inside corner. So my question is does anyone know if the 05 headlights that they say only fit double cab will fit into my access cab. Being that it already has the 05 lights then all 05 lights should fit? Or is there a difference from access cab headlights an double cab headlights?
  22. Jul 13, 2020 at 4:45 PM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    No double cab headlights are bigger than access cab ones
  23. Nov 16, 2021 at 7:22 PM
    Tripledubya
    Tripledubya New Member
    Bill
    2004 Tundra limited 4X4 crewcab 4.7L
    Tore the skin up on it hunting!
    I am hunting for a 2004 tundra crew cab led headlight conversion assembly ( not just the bulb) and having trouble finding them. I see the bulbs but would like a newer look. Help.
  24. Nov 17, 2021 at 5:36 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    2004 Double Cab Tundras are the red-headed step-child of headlight assemblies. The 05-06 Double Cab Tundra assemblies don't work without retrofit/ modifications.
    I believe 01-04 Sequoia headlight assemblies are the same as 2004 Double Cab Tundras... but still, your options are going to be pretty limited.
    Headlight Revolution likes this.
  25. Nov 17, 2021 at 10:24 AM
    shifty` I'm having daydreams about night things
    Paging @Headlight Revolution
    Their website: https://www.headlightrevolution.com/
    They can get you a retrofit kit, to which you can retro your own. There's a thread here you can find via Search that shows the process.
  26. Nov 17, 2021 at 11:05 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    ...and in many other cases as well. What a "unicorn" lol.
  27. Nov 23, 2021 at 11:16 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Happy to help if needed! :)
    Sales@HeadlightRevolution.com
  28. Jan 14, 2022 at 7:13 PM
    gsxrman
    gsxrman New Member
    Hey everyone, read the discussion and decided to sign up and ask question.
    I have 2004 Access Cab, my biggest concern is performance. Stock lights just really suck, the fog lights are almost better. Looking for a kit that can replace both and light up the road without a lot hassle, drop in replacements that actually do the job! Anyone have experience with a product that really does what most claim to do? HID or LED which direction? Really liked the look of the ones at top of post, just not sure they will get-er-done! Suggestions? I've tried many times to polish the stock lenses only to degrade in a few months...Looking for a permanent good solution that will allow me to drive on dark roads at night again. TIA for any suggestions.
