Will +18mm rims and 285/70r18 tires clear after market control arms
Discussion in 'Wheels & Tires' started by Roberttundra, Jul 20, 2022.
  1. Jul 20, 2022 at 7:42 PM
    Roberttundra
    Roberttundra [OP] New Member
    I wanna get wheels they are 1mm offset and I was going to put 285/70r18 tires on it with the 2.5 inch lift will I have any problems with the aftermarket upper control arm hitting or will I have any rubbing
  2. Jul 21, 2022 at 9:20 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No, +18 gives a lot of clearance for the UCA. 285/70-18 will also fit on a stock truck, no lift, stock UCA, no issues. +18 you will need to lose the front air flaps on bumper, may need to trim or remove front mudflaps.
  3. Jul 21, 2022 at 10:41 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Considering this and the other thread you made an hour earlier, your brain is obviously addled. Figure out what is wrong with the spacer lift you got... why it pops and rides like crap. Don't buy anything.
