Wikid's Tundra
Discussion in '2.5 Gen Builds (2014-2021)' started by Wikid, Jun 9, 2015.
  1. Jun 9, 2015 at 3:33 PM
    Wikid
    Wikid [OP] New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    I thought I would start a build thread
    2015 Platinum Crewmax White
    Leaving the dealer . I actually special ordered it in March, because I wanted a non flex fuel version, which at the time, they didn't offer in the southwest. I ordered the typical, garnish, with the platinum, along with adding the Amp Research, steps.
    Here would be the real reason for not getting a Flex Fuel model. The Supercharger was waitng at the dealer, before the truck arrived. installed with 8 miles on the clock
    Also waiting at the dealer was this
    and this..
    Transfer Flow replacement fuel tank.
    The tech at the dealer, said it would be no problem to do the tank install, while installing the s/c ,since the tank needed to be dropped anyway. It only added 1 hour ,to the install. He said they use every available inch, in that tank location
    Here is what 3/4 of a tank of gas looks like
    After I brought it home, this was waiting for install.
    Ba Muffler dual TRD Replacement , with TRD Tailpipes. I painted them with several coats of semi gloss grill paint and heat treated them before the install . This is a mellow system, since I really wanted to keep the drone and cabin noise down, but it is louder than the TRD
    6f73b402-894d-4abd-971f-f39cdc5097e4_zps_2b8968162c0a8d9fc555cdff4ce2944f79b89f1b.jpg
    More stuff to add
    Engel Refrigerator, will be put behind my seat (since we don't have many passengers) Easily removed when I do. It will stay in the truck along with having a dual battery, solar panel, Ham Radio, cb, and more
    This build will not be one of these way over the top, spacer lift builds.
    The plan is to run 35" tires with a full suspension under it. I am building this to drive, camp explore and even have a little romping fun .
    I decided I love the look of the Rock Warrior wheels, that falls in line with the function of this truck 17" , light, strong and will fit, with close to the back spacing I want to run. More on this later
    A company named OMF actually can take these and machine the front lip, to add true bead locks and rings . I am considering this, but the extra maintenance involved and cost to do it, will be factors that I consider. It would look awesome though
    ARE Z Series shell
    This will fall in line with my future mods. I will be doing a hard shelled , Roof Top Tent. I also have a 17 ft Viking camper, i will pull to events and destinations, but the Roof Top Tent will be in place, for when I pull a car trailer, with a first Gen 4 Runner, for harder trails and rock crawling . Then I still have camping off the ground, which is big for the wife .
    More to follow Next up... suspension
  2. Jun 9, 2015 at 3:34 PM
    Wikid
    Don
    On order
    Suspension
    Is planned out and on order .
    I decided long travel would be way over the top and not practical for the purpose of this build, but I wanted to have a really well put together mid travel set up, for when I want to put some of the extras power to use off-road
    Here is the plan
    Total Chaos
    http://chaosfab.com/ will add additional shock hoops for the front, along with other key stuff to make the suspension work correctly
    We will be adding Fox 2.5 remote resi's, with dual compression and Fox 2.5 triple bypass, for the secondary shock, custom valved . http://www.ridefox.com/
    The rear will be Fox 2.5 remote resi's and Deaver is making a custom ordered spring, that will give me a little compromise between super flexy and a little load carrying. TC will provide the new shackles. I will add Firestone 2445 air bags, for the additional trailer weight, when I pull the 4 Runner.
    Install is set for end of July, since some of it is custom made
    Other things in the works
    Install my ExtremeAire compressor system, with tank, under the truck , probably where the spare tire is, along with a Horn Blaster air horn, for distracted drivers. :)
    Spare tire will be mounted inside the bed, along with some sort of storage system.
    Here is the link to my install on my previous FJ Cruiser. it will be a similar install on the Tundra
    ExtremeAire Compressor install - Toyota FJ Cruiser Forum
    Lighting
    Baja Designs will be my choice, once again
    Once I get the rack for the Roof Top Tent, bumpers, front and rear, I will design a complete lighting system, that will give me the coverage I had with my FJ
    I am working with a lighting control company to design the best possible solution, for controlling all my electronics. It should be awesome.
    Off-road navigation will probably be handled, by I-pad mounted with GAIA navigation
    More to follow including when I decide on tires
    A Care crate arrived from Toyota today
    the red, Flying Yota, TRON and 4 others like this.
  3. Jun 9, 2015 at 4:33 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Dude... You are going to have one Bad A** truck. :bowdown: Hows that supercharger feel?
  4. Jun 9, 2015 at 5:15 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Welcome, Welcome, Welcome, and thanks for joining the forum. Lots of awesome things going on here and should be a sure pleasure to drive. Lucky You!
  5. Jun 9, 2015 at 5:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Welcome! I can't wait to see this build!
  6. Jun 9, 2015 at 5:43 PM
    Welcome. WOW! So when do you plan to do some serious mods?(sarc) Like everything. Do you know if transfer flow makes a tank for the double cab? Guess I can call them. Their ph# on the label. Very cool truck.
  7. Jun 9, 2015 at 6:21 PM
    Just checked. Transfer flow does make a DC version for $1179.00. Thinking you should get over 600 mile range. I checked out T Flow's website last year when I bought my Tundra and I thought all they made was for diesel. This has moved into second place behind the limited slip. I have a tendency to drive long distances at times where fuel is scarce. Good luck keeping your foot of the gas. Heh heh. Super nice truck. Well thought out.
    tat2ude39 likes this.
  8. Jun 9, 2015 at 6:26 PM
    Wikid
    Don
    On order
    Thank you
    I couldn't drive it for more than 1/2 throttle, for the first 500 miles, but I could feel the beast in the peddle, waiting to unleash holy hell !!.
    After the 600 mile mark, I pulled out of a side road and romped it on a roll, doing about 10-15 mph. I literally giggled, like a little school girl. I call it my 7000# sportscar . It is a real pleasure to drive. Smooth, hard acceleration, that never seems to go away
    Thanks. This is what keeps me going. I love building. This is a bigger challenge than the FJ . EVERYONE has a huge , lifted full size truck, that gets attention because of the bling. I want this to be remembers for a truck you want to drive... everywhere.
    Thank you
    I will be looking over all the nice builds here. I think you get all of the best, out of guys that share what they do
    Thanks
    I believe the gas tanks are exactly the same for both the Crewmax and double cab. Give them a call and tell them I sent you. It is truly the second best mod I have done so far. The ability to go by gas stations instead of stopping at every other one, is awesome. I also get a little better gas mileage than non boosted Tundra's , as long as I keep my foot out of it. :cheers:
  9. Jun 9, 2015 at 6:32 PM
    Do you recall what the dealer charged to install the tank? There is a good chance the tank may move to first place. Decisions. I've had an auxiliary or replacement tank in every truck I've owned except for my 09 Tacoma.
  10. Jun 9, 2015 at 6:34 PM
    Mike Tread lightly.
    south carolina
    Good looking truck man. Cool mods so far.
  11. Jun 9, 2015 at 6:38 PM
    The tank looks like you ordered it with the special optional coating for $150 list.
  12. Jun 9, 2015 at 6:47 PM
    Wikid
    Don
    On order
    You will have to get the list of qualified installers. I had quotes from $500 to $280
    I got a little lucky, because I had the tank shipped to the shop that was going to charge me 280. Then I realized that they need to drop the fuel tank, to install the new pump for the blower. I Sent the directions to the tech and asked him if he could just put the tank in when he swaps the pump. He only charged me (1 hour), shop time, to do the swap. He said it was straight forward. The shop was really cool about it and then I decided to buy a prodigy brake controller, just to pass good karma on.
    thank you
    I did get the coating . My opinion is that it's worth it, Gives it a little protection and keeps the rust away The stuff is thick and very pliable
  13. Jun 9, 2015 at 7:13 PM
    Nice!!! Where is this money tree at? :)
    How many gallons does the transfer flow tank hold?
    zcarpenter92 and tat2ude39 like this.
  14. Jun 9, 2015 at 7:14 PM
    U should submit some of ur mods to the contest we are holding! $50 Toytec gift card is at stake!
    MotoTundra likes this.
  15. Jun 9, 2015 at 7:19 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Watching all these builds is so much fun... Take a piece of good info from each member... We'll be moding for the rest of our lives, lol.
    MannyFresh, Wikid[OP] and Black Wolf like this.
  16. Jun 9, 2015 at 7:26 PM
    Lol pretty much what I do! The more ideas the better!
    MannyFresh and Wikid[OP] like this.
  17. Jun 9, 2015 at 7:26 PM
    tuna813
    tuna813 New Member
    Tuna!
    13' RCSB
    Impressive.. must say I am now intrigued in the tank and see a ton of value in it. Great job
    Wikid[OP] likes this.
  18. Jun 9, 2015 at 7:32 PM
    Thanks for that info. Coating is worth it. I've got some thinking to do.
  19. Jun 9, 2015 at 7:32 PM
    46 gallons. It's a replacement tank. Aluminized steel I think
    T-Rex266[QUOTED] likes this.
  20. Jun 9, 2015 at 7:32 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    It does sound like a great addition, but not sure if I'd have any money left to buy gas after buying that bigger tank... Would be great for road trips or long off road excursions though.
    Wikid[OP] and Black Wolf[QUOTED] like this.
  21. Jun 9, 2015 at 7:37 PM
    This is getting good. What do you think about that tank? Pretty handy in the the AZ desert I'm thinking.
  22. Jun 9, 2015 at 7:38 PM
    Put it on your list of possibilities.
  23. Jun 9, 2015 at 8:06 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    It's now on my list... (Sigh). It would definitely come in handy in July. Was thinking to do a little road/camping journey with my boy, from here up into Colorado. Maybe I'll have a opportunity to meet some of you mountain boys. :)
  24. Jun 9, 2015 at 8:13 PM
    #1 No doubt about being handy. #2 We're waiting.
    tat2ude39[QUOTED] likes this.
  25. Jun 9, 2015 at 8:26 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome. Looks like you've put lots of time and thought into selecting the best additions for the truck.
  26. Jun 9, 2015 at 8:37 PM
    Wikid
    Don
    On order
    Bingo!!!
    If you play your cards right, you can save a few bucks. Just think of the expensive areas to buy gas. You can avoid them .
    When I go to California, I fill up right before I leave AZ. Then I only buy enough gas to get back to the border of AZ . Then fill up Thats how you can save some bucks
    Yes thats the plan
    I will be taking a pretty long trip this summer. Going to Yellowstone, for about 1 week, then off to Ouray Colorado for an FJ Cruiser Event . Too bad my lift won't be ready yet. I will be pulling my 17 ft viking, so the extra gas will keep me from stopping every 200 miles at about 10 mpg
    If you saw my first 2 FJ builds , you would see where I started and all the mistakes I made with the first one, then the improvements to the second one( Main thing was planning every thing out so you don't buy stuff more than once ). Some of it does end up morphing, because one idea leads to another , but I still try to research which is the best way to do it. The first question you should ask yourself, when you decide to build is.. How am I going to use this truck?
  27. Jun 9, 2015 at 8:41 PM
    I need to find a way to morph my wallet.
    Wikid[QUOTED][OP] likes this.
  28. Jun 9, 2015 at 8:44 PM
    Wikid
    Don
    On order
    I must be missing a definition of one of the words what does the term "ur miss" mean? Obvious that its just a typo but I couldn't figure out what to replace it with. Thanks
    I love reading and seeing other builds. Lets face it, there are only so many things you can do to a truck Or Should :der:.
    Ditto
    Yeah ,,when you start thinking about how you can use it to extend your pleasure. Wait , that doesn't sound right :facepalm:
  29. Jun 9, 2015 at 8:47 PM
    "Your mods"
  30. Jun 9, 2015 at 8:47 PM
    csuviper
    Broomfield, CO
    Sean meant mods. Unique mod competition
    Wikid[OP] and T-Rex266 like this.
