Why won't these fit my truck?
Discussion in 'Wheels & Tires' started by belairbrian, Oct 16, 2022.
  1. Oct 16, 2022 at 2:53 PM
    belairbrian
    belairbrian [OP] New Member
    2016 Crew Max 4x4 TSS
    Is this a case of website be stupid? Or am I missing something?
    2016 Crew Max TSS Off-Road
    Stock tires per the Door Sticker LT285/55r20.
    Want to put on MICHELIN LTX A/T 2 LT285/55R20 122R E1 BSW
    Discount Tire says they won't fit
  2. Oct 16, 2022 at 3:03 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    yeah, that's weird…. it's probably perceiving that you're running an 18" wheel :notsure:
  3. Oct 16, 2022 at 3:32 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Their website always seems to do that. My 2018 also had 265/55/20 which are 32.3”. I ran a 285/65/20 (33.6”) on stock wheels and a 2.75” lift in front.
  4. Oct 16, 2022 at 4:49 PM
    belairbrian
    Just to see if they thought I was running 18's, I went back through the pick your vehicle thing and it came upw with one original tire size , and no alternates. I'd say it's the LT, but it says it needs to be an E1, which I think can only be purchased as an LT.
    I'll try and call tomorrow and see what they say.
  5. Oct 16, 2022 at 5:20 PM
    Rubberdown
    That’s weird. I wouldn’t think any tundra would weigh enough or carry enough to need E load range tires.
  6. Oct 16, 2022 at 7:17 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I always run an E load as I like the 10ply for off-road and the added sidewall stability for towing. Ran them at 45psi cold.
  7. Oct 16, 2022 at 10:56 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I had the same issue for trying to buy/install 315/70r17. I ended up saying I had a Raptor (stock tire size) to complete the purchase haha. Techs were confused for a minute but thought it was funny/all good. Looks like there are some vehicles that have 285/55r20 stock just plug these in to complete the purchase:
  8. Oct 17, 2022 at 12:25 AM
    blenton
    blenton New Member
    You just have to search by tire size instead of vehicle, then ignore the warning that the tire won't fit. Unless you have some strangle local ordinances, they shouldn't have any issue mounting the "odd" sized tire not spec'd for your truck (even though it obviously was spec'd for your truck).
  9. Oct 18, 2022 at 8:52 AM
    Rubberdown
    Cool for you. But it’s not required and odd that they would say it is.
  10. Oct 18, 2022 at 10:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    with Discount tire, search for tires based on size, not vehicle. they will only show stock tires available if you choose tire by vehicle and they only list the standard tires/rims, usually not the TSS options.
    So just browse and buy based on the tire size you want to run.
    1lowlife likes this.
  11. Oct 18, 2022 at 12:10 PM
    belairbrian
    So here is what I ended up doing, While they list the TSS as atrim package and it returns the correct tire it will not let you checkout.
    So I ended up selecting SR5 4x4 with aluminum rims then changing to the alternate tire size 285/55r20. it hen let me select the same exact tires and checkout.
    Now here is where it got a little wierd,in a good way, when I did it that way I received a $110 Michelin discount on the set. Which dropped the per tire price under $300. It said the discount was good September 7 – October 23, 2022 but only for online orders. But I would bet they would do it in store if you asked.
  12. Oct 18, 2022 at 3:28 PM
    belairbrian
    Wonder if it's because 35 of the 38 tires they sell in that size are e rated?
