Why isn't the 2004 Tundra covered by the frame recall?
Discussion in '1st Gen Tundras (2000-2006)' started by seachunk2, Nov 19, 2019.
  1. Nov 19, 2019 at 11:40 AM
    seachunk2
    seachunk2 [OP] New Member
    2004 Tunda DC V6 4WD SR5 AT
    When I check NHSTA and other sources it appear that the 2004 Tundra is not covered by the frame recall.
    Is there a reason why it wouldn't be?
    Isn't the frame essentially the exact same as on the earlier and/or later year Tundra's, which are covered?
  2. Nov 19, 2019 at 12:40 PM
    Mid-Atlantic Slots
    Mid-Atlantic Slots Living the semi retired life, Life is good!
    Wayne
    Franconia Va
    2004 Tundra Dbl cab SR5 / TRD 4wd
    A few little things
    The Double cab I have was replaced under warranty.
  3. Nov 19, 2019 at 12:56 PM
    speedtre
    speedtre New Member
    Inland Northwest
    While only 2000-2003 were covered under the recall, Toyota has replaced some frames on every year of 1st Gen Tundras...that doesn't mean they will replace yours, it just means it's not out of the realm of possibility. Good luck.
  4. Nov 19, 2019 at 2:21 PM
    seachunk2
    Isn't the 2004 frame essentially the same? That is, wasn't it manufactured by DANA the same company, using the same standards for corrosion in 2004 as the prior years, etc?
    For those that had their 2004 frames recalled, I suppose it was not easy task. It was just a matter that the frame was obviously rusted through and Toyota just replaced it without any resistance, correct?
  5. Nov 19, 2019 at 2:37 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While to some it might be semantics, 2004 did not have a recall. It was a limited service campaign for certain cold climate states. Thru that campaign some had the opportunity to have frame replaced if inspection determined that.
    https://static.nhtsa.gov/odi/tsbs/2014/MC-10131966-9999.pdf
  6. Nov 21, 2019 at 5:18 PM
    2004.crewcab.tundra.ltd
    2004.crewcab.tundra.ltd New Member
    2004 Toyota tundra crew cab limited
    Hi people!
    I have an 04 crew cab tundra, this cold climate state you are talking about, would Ontario Canada count? Lol
