Why is the 2014+ considered a 3rd gen (forum sub thread)
Discussion in '2.5 Gen Tundras (2014-2021)' started by nodak67, Sep 23, 2019.
  1. Sep 23, 2019 at 9:21 AM
    nodak67
    nodak67 [OP] New Member
    JR
    can someone explain to me why the 2014+ is considered a 3rd gen when the 2007-present tundra is still a 2nd gen technically.
    i know the 2014 was a refresh but its still a 2nd gen.
    same issue they have over in the 4runner ( ) forum where they consider the 2019 a 6th gen and the 5th gen stop at 2017.
    edit: what are you going to call the sub thread when the actual 3rd gen tundra comes out?
    Mountun Goat and snivilous like this.
  2. Sep 23, 2019 at 9:31 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    This has been asked about and discussed before. 2014 changes were more cosmetic, engine / chassis unchanged. I want to say that Toyota is calling them 2.5, or has been said on here before. Body parts and some interior like radio are not interchangeable with 07-13, enough so most just refer to as 3rd gen.
    Ostrich, omgboost, Pinay and 2 others like this.
  3. Sep 23, 2019 at 9:31 AM
    Though it was more of a refresh rather than a new generation, I think the reason for it lies in the incompatibility of some parts. You can't swap the taillights, for example.
    Trooper2 likes this.
  4. Sep 23, 2019 at 9:39 AM
    ToyotaTundraMike
    2015 Tundra
    Same reason they have 2nd 3rd 4th and 5th generation glocks. Did they change the insides with each generation or was it mostly minor cosmetic changes?
    We call them 3rd gen Tundras because it looks nothing like the 2nd gen and makes it easier to differentiate in conversation. Also like others said, many parts aren’t interchangeable.
    Not sure why people get their panties in a bunch over this. When the new ones come out we will call them 4th gen Tundras.
  5. Sep 23, 2019 at 9:40 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  6. Sep 23, 2019 at 9:41 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Because they dont use Johnson & Johnson talcum powder. Turns out it a lil' tough on the cervix.
  7. Sep 23, 2019 at 10:10 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Case closed.
  8. Sep 23, 2019 at 11:26 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    Glocks are a bad comparison. Many of the internals are incompatible between generations
    Glockmeister likes this.
  9. Sep 23, 2019 at 11:32 AM
    bdpeelgren
    Round Rock, TX
    One could say the same between 07-13 and 14+ tundras.
    GODZILLA likes this.
  10. Sep 23, 2019 at 11:48 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Yep, Toyota is still making 2nd generation Tundra trucks, but the 3rd generation trucks are expected to be ready for prime time in 2021.
  11. Sep 24, 2019 at 7:08 AM
    nodak67
    JR
    well if thats the case might as well call the 2019/2020 4th gen since they added a bunch of stuff the 2014 doesnt have. why is this change of gen designation any different than any of the other toyota models? we still call the 2014 4runner 5th gen (since its completely different than the 2009 version), the 2020 tacoma 4th gen even though they changed alot from the 2016 version.
    this so called 3rd gen still has the same major internals as the "2nd gen" series. so i am guessing we will be changing the what we call a new gen based on minor changes that every model gets thru the years that dont fit the older models?
    oh well carry on i guess :)
    Rex Kramer likes this.
  12. Sep 24, 2019 at 7:28 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I’m just curious OP what constitutes a “gen” change to you? I have never been one to care what gen something is myself, vehicles are more of an evolution to me they change something every year.
    I can see this point from both sides, maybe drivetrain is what should be the kicker?
  13. Sep 24, 2019 at 7:36 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Grille.
    Definitely the grille.
    Omohundro, panicman and Pinay like this.
  14. Sep 24, 2019 at 7:37 AM
    bigandtall
    bigandtall New Member
    Indianapolis Motor Speedway
    I don’t know about the OP, but I think a change in drivetrain makes a logical break point between generations.
    Omohundro[QUOTED] and Rex Kramer like this.
  15. Sep 24, 2019 at 7:38 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Fact is, we decide, not Toyota.
    TXMiamiFan likes this.
  16. Sep 24, 2019 at 7:53 AM
    nodak67
    JR
    well i know toyota changes minor things every year on a model to keep it fresh and different from the last model year, otherwise 80-90% of the population wouldnt look at a new tundra (and the average toyota consumer dont care squat about us minorities that know more about the vehicles via forums like this, we probably only constitute about 10% of the toyota buying power of a model).
    the big parts that change/dont change is what underlies the gen model. i mean for the tundra, its the engine, frame, transmission and other major parts that dont change during the whole gen life cycle.
    heck the tundra has gone thru what 2 refreshes on cosmetics alone. the interior has changed numerous times, exterior bits and pieces has changed several times also.
    this happens all the time across all the toyota models during a gen cycle.
    but hey if the forum wants to call it a 3rd gen go ahead but its still a XK50 designator.
    edit: i guess if we want to stretch it, we could call this a 3rd gen since the T100 was the father of the tundra.
    T100 = XK10/XK20
    TUNDRA 1G = XK30/X40
    TUNDRA 2G = XK50
    Omohundro[QUOTED] likes this.
  17. Sep 24, 2019 at 8:10 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    In 2014, Toyota introduced the new generation of Tundra at the Chicago Auto Show. They did change much of the body design (yes, mostly styling changes- but some functional changes, like tailgate spoiler, larger grill) and the interior was redesigned.
    To me, both the facts that Toyota formally introduced it as a new gen, and the fact that you can easily differentiate the 13- from the 14+ by their appearance qualify it to be designated a new generation. Still a Tundra, but a different truck in appearance.
    This reminds me of the other site I frequent that is aimed at vintage VW’s; the bugs, busses, ghias, etc... were never broken up into “generations”, and only after production ceased and the cars became enthusiast collectibles did the enthusiasts themselves break the vehicles up by manufacture date... 1938-1953, 54-57, 58-67, 1968+
    We could do that here.. it would just be a bigger pain in the ass to discuss them, and I don’t know what is perceived to be benefited by abolishing the “generation 3” moniker.
  18. Sep 24, 2019 at 8:33 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Somethings my inner me just goes “dude, move on” then I just continue on with life. I still get paid so I don’t worry about anything that doesn’t directly affect my paycheck.
  19. Sep 24, 2019 at 9:21 AM
    Tundra Fan
    Toby
  20. Sep 24, 2019 at 9:23 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    WINNER!
  21. Sep 24, 2019 at 9:24 AM
    panicman
    Eric
  22. Sep 24, 2019 at 2:08 PM
    nodak67
    JR
    wow that was an interesting reply from corporate. dont think i have ever seen one of those emails before, but then again i wouldnt have thought to ask corporate and get an actual factual reply.
  23. Sep 24, 2019 at 2:16 PM
    nodak67
    JR
