Why is nobody running hydro bumps on the rear
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, Jul 4, 2021.
  1. Jul 4, 2021 at 5:52 PM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    Just curious as to why nobody is running hydro bumps on the rear of these 1st gens ? I can find a lot of 2nd gens and 3rd gens running them
    is it cost? Lack of travel in the rear? Clearance issues? Or are the overkill?
    I mean in the scheme of things they seem like they would be worth the investment to protect an expensive suspension?
    Darkness likes this.
  2. Jul 4, 2021 at 5:57 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes multiple times.
    The only people who would benefit enough to fab mounts and run these are long travel people. They usually have something cool worked out for compression protection. For everybody else a cheap and easy solution like wheelers bump stops or similar is enough.
    I like where you're headed though.
  3. Jul 4, 2021 at 6:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Definitely an up travel thing. When you go spring under you have a lot more up travel to play with
    des2mtn, Darkness and Cummins3500[OP] like this.
  4. Jul 4, 2021 at 6:31 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Thats my plan. But i want high lift deavers under the axles. And i havent decided how much sway bar i want yet. But, hydraulic bumpstops might keep me from needing sway.
    Cummins3500[OP] likes this.
  5. Jul 4, 2021 at 6:50 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Gotta come clean, im not opposed to a truck arm and cantilevered coilovers, cause i dont want to cut the bed. But, im not there yet.
    Sunnier and snivilous like this.
  6. Jul 4, 2021 at 6:54 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If you're relying on bump stops for your sway control then you have effectively no up travel at ride height. I wouldn't recommend that unless it's strictly a crawler and you hate going over 5mph.
    Hbjeff, 831Tun and Darkness like this.
  7. Jul 4, 2021 at 7:06 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    No, it can lean, but the stops would keep it from binding. And…i dunno im not there yet, sas would be worth the death wobble…
    https://youtu.be/LDGWZ1TiAhc
    About 1:05ish: i wouldnt hate carrying tire on on-ramps. And 1:38ish.
  8. Jul 4, 2021 at 7:13 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Agree. DW can be mitigated with a good steering system and beefy steering stabilizer(s).
    Sirfive[QUOTED] likes this.
  9. Jul 4, 2021 at 7:42 PM
    Cummins3500
    Logan
    That mcm fab cantilever setup is pretty damn sexy. And cost wise it would’ve been similar to the full archive garage setup. I just figured I’d never push the truck hard enough to take full advantage of it without long traveling the front end
    curiosity got the best of me about running these air bumps. I wonder if I could squeeze a short set in there. :monocle: I mean the rear end is getting a re-work with the shock relocation kit and hammer hangers. Plus I’m hoping ads can hook me up with a set of shocks that match the compressed and extended lengths archive recommends while maintaining that 12 inches of travel
    https://www.crawlpedia.com/bump_stops.htm
    here’s the link That got me back to looking at these
    Sirfive and Darkness like this.
  10. Jul 4, 2021 at 8:06 PM
    snivilous
    SW UT
    Hydros are awesome and can't be remotely compared to "normal" bump stops, so if you can fit them and justify the expense you should. The only "downside" I've noticed for street use is they can be loud and clanky if you compress the suspension enough to kiss them but not enough to actually make the bump stop move. Of course, that can be remedied by adjusting the pressure in them (so you'll want a nitrogen setup, but that costs about $120 if you don't have one). If you're running 12" of travel I would get 2" stroke ones (though you can destroke any bump easily by installing a spacer, even 2" might be too long depending on how much up travel you have). The tunability is what makes hydros especially nice, and then you get the perk of true bottom out resistance versus just slamming a rubber puck slightly less hard than the frame.
  11. Jul 9, 2021 at 2:20 PM
    Cummins3500
    Logan
    So if space is an issue is their a benefit to running Spc’s with the 1.75 in stroke versus say ads’s option with a spacer to reduce stroke?
    Spc jounce shocks:
    https://www.spcalignment.com/component/content/article?id=371
    https://www.race-dezert.com/forum/threads/light-racing-jounce-stops-whats-the-word.70066/
    *dude in this thread mentions they’re designed to pass GM’s oem test requirements for bumpstops :monocle:
    ADS:
    https://adsshocks.com/product/air-bump-stops-2-125-inch-bump-can-style-ads-racing-shocks/
  12. Jul 9, 2021 at 2:53 PM
    snivilous
    SW UT
    Never heard of them, but they have support in that rdc thread and they appear to be the same as a normal hydro more or less. If they fit your bill I'd have no issue running them, I'd just compare sizes to other bumps on the market.
    And in regard to the ads bumps, I have 4 of them on a build right now (reused from a previous truck I had) and they're pretty standard for bumps, but they are 2.125" which is annoying. You can't just swap out any old bump stop into them, and you can't just stuck a piece of 2" tube inside the can when welding it. I don't know why ads has to be so weird and offer a slightly larger shock for their smallest size, but something to keep in mind. Honestly, if you're not trying to match brands for your shocks I wouldn't run their bumps purely from those reasons alone. All bumps cost essentially the same and all perform the same, not having any interchangeability with other brands and being a weird size for fabrication is dumb.
  13. Jul 9, 2021 at 3:27 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I like to run naked without bump stops.
    Not by choice, just the fact my old ones dried up and fell off.
  14. Jul 9, 2021 at 3:49 PM
    Cummins3500
    Logan
    @snivilous Thanks for the info man, and I’m sure they’ll be more questions come up. I’m trying to not to make a rushed decision and compare all the options. Plus I like seeing real world reviews on em before purchase
    Ads is off the list because I don’t wanna full commit to that odd ball size.
    but the same argument could be made for the SPCS. But I’m gonna keep them on the list for the compact option and the low maintenance side of them.
    @Jack McCarthy we’re just gonna call you “the streak” lol
    snivilous and Jack McCarthy like this.
