why doesn't the "air" turn off??
Discussion in '2.5 Gen Tundras (2014-2021)' started by doughboysigep, Jun 12, 2017.
  1. Jun 12, 2017 at 7:15 AM
    doughboysigep
    doughboysigep [OP] New Member
    Delhi, NY
    '20 SR5 CM 4x4
    I shut of the fan for my AC or heat, but still feel air coming out of vents. Why is this?? Is it common in Tundras?
  2. Jun 12, 2017 at 7:17 AM
    Circulate it
    BuckWallace, geno0506 and Jsena like this.
  3. Jun 12, 2017 at 7:20 AM
    Yeah hit recirculate button
    geno0506, ChrisTRDPro and TRD15559 like this.
  4. Jun 12, 2017 at 11:20 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    That's common in any modern day vehicle.
  5. Jun 12, 2017 at 11:29 AM
    15whtrd
    15whtrd Mr. Blonde
    Pretty sure it's just the outside air you're feeling coming through the vents. The velocity of the air picks up as you drive faster too. Put it on recirculate in it closes that vent to the outside air.
  6. Jan 30, 2018 at 8:29 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    now that it's winter, I get a lot of hot air out of my dash vents when on windshield and even floor. need to keep them shut and they get HOT. recirc doesn't seem to help much with this.
    JH5370 and PermaFrostTRD like this.
  7. Jan 30, 2018 at 8:34 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    I've had mine off, but after driving for 30-40 minutes, the circulate button shuts itself off. Heard it had something to do with pressure?
    geno0506 likes this.
  8. Jan 30, 2018 at 8:35 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    All modern vehicles have a fan that runs continuously. Fresh air circulation inside the cabin.
  9. Feb 1, 2018 at 1:53 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    You will always get fresh air inside the cabin even with the hvac system off. Reason being it's all about the legalities, so you don't asphyxiate yourself and for cabin pressure. If your door seals are in good working order you would have a hard time closing the doors also.
  10. Feb 1, 2018 at 6:31 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    My issue is that when I have the air directed to the floor I still get a good amount of air flow through the dash vents, enough that I have to close them not to feel it. I have never seen this in any other vehicle I have
    PermaFrostTRD likes this.
  11. Feb 1, 2018 at 6:35 AM
    Berettafan
    Berettafan New Member
    2017 CM
    great question, have wondered that myself! the truck just knows better than us I guess. positive cabin pressure I guess would aid in preventing any poisoning from exhaust gases.
  12. Feb 1, 2018 at 7:50 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Had the same thing with my 2014 Silverado; also a topic that got a lot of attention on the GM truck forum...
  13. Feb 1, 2018 at 9:56 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Mine does this too. I had it checked by the dealer and they all had looks on their faces that were not helpful. It is the dumbest thing I've seen on this truck other than the fact that the driver's seat is off-center with regards to the steering wheel... About an inch. Dam OCD. When I mentioned that, They had the same looks on their faces, and then ran to another Tundra to see if it was just mine, but it's all of them. They eventually got back to me and said "dunno" about the seat and that it is mandatory that all new vehicles have a constant fresh air flow. I said fine but why, if I only put the vents to floor mode, does it still blow in my f@cking face! I have all my dash vents closed, but it is just plain dumb to have this slip through their R&D. My dealership is good but they don't build the truck, they just service it, however Toyota makes it , however dumb. Aggravating, but not a deal breaker. Still love the truck but wtf sometimes. Right!?
    PermaFrostTRD and darkknight2014 like this.
  14. Feb 1, 2018 at 10:13 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I've only been able to get the recirculate to turn on when the AC is on, is that normal? I'd check my manual but it's not handy right now.
    Edit: Can't have the defroster on with circulation, tested this morning.
  15. Feb 2, 2018 at 7:31 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Any idea on how we can make the recirculate button stay engaged. It turns off every 3-5 minutes on my truck, very annoying...
    1rooster likes this.
  16. Feb 2, 2018 at 8:07 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    I brought my to the dealer about the vents not shutting off. The service rep said it is normal and they also checked a few new Tundra's on the lot and they all did the same thing. Oh well.
    Kurt
  17. Feb 2, 2018 at 4:33 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I can't stand this also. I like the heat blowing on the floor. NOT in my face. Dash vents always have air flow no matter the settings.
  18. Feb 3, 2018 at 8:43 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I’d like to know also, does the same thing also when i turn on the defroster no recirculation, and im damn lazy to read the manual, but not lazy to read this thread. Must be normal.
  19. Feb 4, 2018 at 4:21 AM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    My first generation Tundra's fresh/recirculate could be applied in any of the settings. The limitation on my 2017 is frustrating. I wonder if this is something that can be changed using Techstream?
  20. Feb 4, 2018 at 5:22 AM
    PermaFrostTRD
    Northern NY
    Mine does this too. In the winter I alternate the windshield only (startup) and windshield/ floor combo when driving. Otherwise the wipers freeze to the windshield.
    My solution is that I close the 2 center dash vents and angle the 2 outer vents onto the driver/ passenger windows so it acts like more defrost. I can usually keep it comfortable/cozy by adjusting fan and temp (SR5- no climate control).
    15whtrd and Toyotoholic like this.
  21. Feb 4, 2018 at 5:30 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Turn direction on dash,turn off fan ,push recirculation button done
    NewImprovedRon likes this.
  22. Feb 4, 2018 at 9:04 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I adjusted the vents the same way in a last ditch effort to justify the core ridiculousness of the debacle... Oooooh, I'll get more defrost... Lol I preached to myself that I will be OK just stop thinking about it because there is nothing else we can do. My 06' only put the air, where it was set to... I guess Toyota is "going places" but it appears to be backwards with this one.
    kenomouth64 likes this.
  23. Feb 12, 2018 at 12:47 PM
    Wutachampion
    Wutachampion New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    I am not confident on my answer but I just came from a Tacoma and on TW someone posted if you hold the recirculate button down 3 seconds or so it'll stay on recirculate.
    kenomouth64[QUOTED] likes this.
  24. Feb 12, 2018 at 1:47 PM
    kenomouth64
    Tetrus
    Really!!! You have no idea how happy I would be if this worked.
    Update: It did not work for my truck...
    Wutachampion[QUOTED] likes this.
  25. Feb 27, 2018 at 10:00 AM
    Dkm35allegro
    Dkm35allegro New Member
    Is it me or does tundra floor heater does not blow as hard. I have it on the max and it feels like it’s on low. Had the dealer look at it and they said it normal.
  26. Feb 27, 2018 at 7:26 PM
    Part_time
    Oregon
    Turn direction knob to dash. Turn fan off all the way left. Push recirculation button. No air will come out, put you in hand on it.
  27. Mar 7, 2018 at 10:52 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    problem is, I want/need the heat on (floor and/or windshield) and I can feel heat on my face (which I do not want). Bit annoying really.
  28. Mar 7, 2018 at 12:27 PM
    JoshO
    JoshO New Member
    2018 Magentic Gray Tundra
    Have the same problem. Heat coming out Dash vents even though they should be closed off since I have it set to come out the floor vents.
