Why doesn't our oil get dark? or, checking oil level is hard on a tundra.
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Jan 18, 2020.
  1. Jan 18, 2020 at 12:16 AM
    Aerindel
    Aerindel [OP] New Member
    Montana
    Long story, I did an oil change yesterday because it had been neglected and was at about 7k miles. Oil was light honey colored.
    Now, every other vehicle I've had it would be coal black after a couple thousand, and light brown a mile after a change.
    But not on the tundra.
    Do to my own carelessness I put the wrong filter on and it blew off as soon as I started the truck, vomiting a large amount of oil on the ground.
    I refilled it....but I've been having a hell of a time figuring out how much to put in....because even after a few miles of driving the oil in the truck is so clear I can't be sure if I'm seeing it on the stick or not. Sometimes the stick looks dry...sometimes it looks full.....
    Anyway....what is the actual thing about our engines that keeps the oil so clean?? I've never had another vehicle where the oil stayed like this.
  2. Jan 18, 2020 at 12:35 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    They idle at low oil pressure.. no rocker arms or anything like that in the valve train. Aka less moving parts. Toyota’s in general are easy on oil. My corolla oil is a dark gold after 20k on the oil.
    Fill spec with the d3 oil filter is 6.5 quarts. Even if the oil is clear it should see be easy enough to see on the stick unless the stick isn’t clean (varnish)
  3. Jan 18, 2020 at 12:52 AM
    Aerindel
    Montana
    Yeah, I know how much was supposed to go back in, the problem is I don't know how much I puked into the driveway, and everytime I check the oil I seem to get a different reading, from full, to nothing....which makes no sense so I assuming I'm reading it wrong some of the time.
  4. Jan 18, 2020 at 3:13 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    It is hard to see, but all you can do is fill it half quart at a time. I usually look at it at different light source and angle to see a difference in reflection from the stick and fluid coating the tip.
    shellshock, 15whtrd and Rex Kramer like this.
  5. Jan 18, 2020 at 4:52 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The key to checking it is to not just wipe the dipstick, but to dry it off using a clean absorbant rag or paper towel.
    With any vehicle, I prefer to check oil first thing in the morning -- all the oil is settled, and it's at its thickest. For an even easier read, you could pull the dipstick the night before. That way when you insert in the morning there's no residual oil in the dipstick tube.
  6. Jan 18, 2020 at 5:11 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    When I went from Castrol Full Syn to Mobil 1 on my last oil change, I too had difficulty and have decided until I can see it better, I check at least 3 times before feeling good I'm seeing what I am seeing. One issue I'm still trying to determine is does Mobil 1 run much higher temps on starting in morning. Mine sits at 3/4 for a few minutes then settles to normal 1/2 way mark.
  7. Jan 18, 2020 at 5:22 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    My pennzoil is dark after 5k miles
  8. Jan 18, 2020 at 5:56 AM
    Professional Hand Model
    Hand Protectors
    Trick Tip: Score some diagonal hash lines on your dip stick.
  9. Jan 18, 2020 at 6:00 AM
    Hand Protectors
    Ewwww!
    Mobil 1 High Mileage Synthetic user and this doesn’t happen on the 02.
  10. Jan 18, 2020 at 6:09 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Dry the dipstick off real good stick it all the way in then pull it out and touch it to a towel or rag, and the wet spot will show you how high. Some of us older people can't see that good anymore, so I came up with this idea for myself.
  11. Jan 18, 2020 at 6:28 AM
    tvpierce
    Maine
    The coolant temp gauge?
  12. Jan 18, 2020 at 6:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Honestly, I don't have any trouble reading the dipstick on my Tundra unless it's during the oil change. My oil will get dark after a few thousand miles. I use Mobile 1 full synthetic.
    It got black as tar when I did the Liquid Molly Oil Flush. That was neat!
    I've found that one side of the dipstick is more accurate for some reason.
    Here it is this morning. Pic makes it look low but in person it's not.
    Volt92, MrAristo and hammeron like this.
  13. Jan 18, 2020 at 6:30 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    That’s not a temp gauge, it’s a pressure gauge.
  14. Jan 18, 2020 at 6:50 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    My bad, good catch....I am speaking of oil pressure gauge. Given We are in the Smoky Mountains for the weekend, must be suffering from mountain air :eek2:
    Will post up pic on return home showing what I am speaking of.
  15. Jan 18, 2020 at 7:00 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It's an interesting problem to have isn't it? I change my oil about the 5k mark and its black going out, but on the dipstick it's not nearly as dark. When I put the fresh oil in it looks damn near dry, I have to touch it to know that there is oil on the dipstick and it's high enough up.
    One side is definitely easier to read. The dipstick tube takes quite a curve as its passing the block, I think that forces the bottom side to wipe clear. The side that faces the motor when you dip tends to be easier to read.
  16. Jan 18, 2020 at 7:11 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I have over 355k miles on my engine, go 7,000 miles till an oil change and it's still gold. I use plain Valvoline 5/30.
    1lowlife and bmf4069 like this.
  17. Jan 18, 2020 at 7:17 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Do late model 1sties have the maintenance reminder light for oil changes?
    Volt92 likes this.
  18. Jan 18, 2020 at 7:26 AM
    Hand Protectors
    Thats normal then. Mine has ‘abnormal’ high pressure on cold starts. Tempers out to ‘normal’ lower pressures once engine has warmed. NORMAL!
  19. Jan 18, 2020 at 7:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nope.
  20. Jan 18, 2020 at 7:45 AM
    Hand Protectors
    I flip my dipstick over and check both sides. The highest side is the true reading. Glasses help if your sight is diminishing. Fresh fluid is hard to read, but the tale tell tension line is always there. Sun angles or flashlight will help reveal it.
    KarmaKannon likes this.
  21. Jan 18, 2020 at 8:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hell, I'm still trying to find a longer dipstick. Mine wont reach the oil. :anonymous:
    lsaami likes this.
  22. Jan 19, 2020 at 6:16 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Try a Transmission Dipstick from a Ford Econoliner Van. :facepalm:
    bmf4069 likes this.
  23. Jan 19, 2020 at 6:43 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    That's cuz the oil is still too new....wait another 50K....
  24. Jan 19, 2020 at 4:27 PM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    How many miles does the average owner change? It’s my 2nd car, so I’ll maybe put 5-600 miles a month? My main car is also a Toyota (Lexus), I use 5w-30 or 0w20 every 8-10k miles.. mind you I put on well over 1k miles a month on her.
  25. Feb 7, 2020 at 11:44 AM
    Cody06tundra
    Cody06tundra New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    Mine does
  26. Feb 7, 2020 at 11:46 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    He said late model 1st gens. I took that as the early ones, 00-03? We don't have maintenance reminders.
  27. Feb 8, 2020 at 10:17 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    Just changed mine. It’s definitely what the other users posted. Stick in you’re dip stick WIPE DRY and check a FEW times. 4th time should be accurate on the side with the raised dots. It holds oil to view when taking the turn through the dip stick tube. It should be visible... even fresh oil.
  28. Feb 10, 2020 at 8:35 AM
    Cody06tundra
    Cody
    Oh ok. I got ya.
