Why doesn't my Tundra have overdrive?
Discussion in '2nd Gen Tundras (2007-2013)' started by dbeans1, Jun 15, 2016.
  1. Jun 15, 2016 at 6:22 PM
    dbeans1
    dbeans1 [OP] New Member
    donald
    2014 4.6 liter dbl cab sr5
    Hello guys, im a newbie. My question is: why doesn't my tundra have overdrive? Is it because i have a 6 speed in my 2014 4.6 l tundra?
  2. Jun 15, 2016 at 6:40 PM
    You have a double overdrive. 4th gear is 1:1 ratio.
    Welcome to the site.
  3. Jun 16, 2016 at 10:21 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    You should have a Tow/Haul button, same thing essentially.
  4. Jun 16, 2016 at 12:18 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Tow haul changes the shift points and increases throttle pedal responsiveness. It has nothing to do with overdrive.
  5. Jun 16, 2016 at 1:05 PM
    Nor7
    Well you're partially right. Years ago since the average driver didn't understand overdrive the automakers started using Tow/Haul instead of overdrive. Kinda backwards from what it used to be. My point is that since there's a Tow/Haul mode that means there is an overdrive.
  6. Jun 16, 2016 at 2:51 PM
    jberry813
    Lake Tahoe
  7. Jun 16, 2016 at 3:12 PM
    RockLbstr2011
    RockLbstr2011 New Member
    2011 Crewmax
    Sorry to thread jack but is this for real. Do people really give a flying shit about gas mileage? It is a full size truck.
    JAMES, Black Wolf and T-Rex266 like this.
  8. Jun 16, 2016 at 3:27 PM
    Nor7
    Ok. The long explanation. Overdrive used to be a separate box on the back of the gearbox that you had to engage or turn on. Then it became an automatic feature that you had to turn off when you were towing so the higher gears wouldn't wear out. Now the 'overdrive off' button has become the Tow/Haul button and extra features like shift point adjustments were added to larger vehicles like trucks for better towing performance. Technically overdrive no longer exists in modern day transmissions but the Tow/Haul mode is the modern day equivalent of turning it off.
    RockLbstr2011 likes this.
  9. Jun 16, 2016 at 3:34 PM
    Nor7
    Yeah good point. Nobody really buys a full size truck for its fuel efficiency.
    RockLbstr2011[QUOTED] likes this.
  10. Jun 16, 2016 at 8:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Uhhhh....okay?
    jberry813 likes this.
