why does my 2000 tundra cut out while accelerating
Discussion in '1st Gen Tundras (2000-2006)' started by chasesmith343, Sep 8, 2021.
  1. Sep 8, 2021 at 12:04 PM
    chasesmith343
    chasesmith343 [OP] New Member
    chase
    white 2000 tundra
    stock
    it only does it during the day time not during the night.
  2. Sep 8, 2021 at 12:09 PM
    15whtrd
    15whtrd Mr. Blonde
    I laughed at first. Then I thought, maybe it has something to do with your charging system or battery. Because at night your headlights are on, taxing the system. Start off by checking the voltage of the truck at idle. Hopefully it’s somewhere between 13.5 and 14 V. Then maybe try it with your headlights on. How old is your battery?
  3. Sep 8, 2021 at 12:09 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Vampire truck?
  4. Sep 8, 2021 at 12:18 PM
    15whtrd
    15whtrd Mr. Blonde
    You’re right, I miss read that. I thought it was only doing it at night. Vampire truck for sure
    YardBird and bmf4069[QUOTED] like this.
  5. Sep 8, 2021 at 12:20 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    when reving to about 3-4 thousand rpms and let off the gas it acts like it wants to die but doesnt.
  6. Sep 8, 2021 at 12:22 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe time for a little tuneup. Clean your mass airflow sensor and throttlebody, Check your spark plugs, they may be due. And maybe think about a fuel system cleaning. There are write ups around here.
    Casper421, KNABORES and FrenchToasty like this.
  7. Sep 8, 2021 at 12:23 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    brand new fuel pump and fuel filter
  8. Sep 8, 2021 at 12:26 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Does it do it when you first leave or after it's warmed up?
  9. Sep 8, 2021 at 12:30 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Day vs night - temp difference? Vacuum hose leak? Faulty plug wires?
  10. Sep 8, 2021 at 12:31 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    sometimes it does it and sometimes it doesnt when im driving.
  11. Sep 8, 2021 at 12:32 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did you get those CPS wires crimped back in good? Solid connections?
    15whtrd likes this.
  12. Sep 8, 2021 at 12:33 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
  13. Sep 8, 2021 at 12:34 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    still acts like it wants to die at reving 3-4k rpms
  14. Sep 8, 2021 at 12:35 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Any problems starting the truck?
  15. Sep 8, 2021 at 12:35 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
  16. Sep 8, 2021 at 12:36 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    fires right up.
  17. Sep 8, 2021 at 12:37 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Any CEL or codes?
  18. Sep 8, 2021 at 12:38 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
  19. Sep 8, 2021 at 12:41 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sounds like either fuel or evap system, possibly both. Like it's not getting enough fuel to run up high.
    wandering_boy, alb1k and 15whtrd like this.
  20. Sep 8, 2021 at 12:43 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    has brand new fuel pump and fuel filter .
  21. Sep 8, 2021 at 12:44 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    i dont have any cats because they were clogged. so i cut them out.
  22. Sep 8, 2021 at 12:46 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm thinking more along the lines of the heat of the day causing a pressure build up in the fuel system. I could be way off as I have been before, but that's all I can think for the night/day issue.
    15whtrd likes this.
  23. Sep 8, 2021 at 12:48 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    how do i fix that ?
  24. Sep 8, 2021 at 12:49 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Let somebody smarter than me chime in and see what they say.
    N84434, FrenchToasty and FirstGenVol like this.
  25. Sep 8, 2021 at 1:12 PM
    Sounds like there's a lot going on here. No cats, Cam sensor wire splicing, fuel pump has already been replaced etc. I would retrace all prior work and look for any problems you may have missed. Was the truck giving you these issues prior to the fuel pump replacement? Prior to the Cam sensor issue? When you say it acts like it wants to die but doesn't at 3000 rpm, what do you mean exactly? Could be any number of issues, you'll have to eliminate them one by one. No CEL with a truck that isn't running right is odd. Spark plugs, MAF sensor, TPMS sensor, injectors, evap system, charging system and battery, the list goes on and on.
    N84434 likes this.
  26. Sep 8, 2021 at 1:15 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    it never acted like this b4 cats got plugged after i took the cats out it started having issues.
  27. Sep 8, 2021 at 1:17 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    like the truck goes down below 1000 rpms . like super low then jumps back up to normal idling rpm.
  28. Sep 8, 2021 at 1:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Are you getting CEL ‘s?
  29. Sep 8, 2021 at 1:19 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    no the only to lights that are on is the engine light and then the a/t temp light but as soon as the truck is running they go away.
  30. Sep 8, 2021 at 1:22 PM
    chasesmith343
    chase
    white 2000 tundra
    stock
    it also has new spark plugs and coil packs.
