Why Did You Cut Me?
Discussion in '2nd Gen Tundras (2007-2013)' started by Les7311, Feb 8, 2017.
  1. Feb 8, 2017 at 8:32 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    6 inch Rough Country Lift kit installed on 35 shoes. Got truck back in the night so no real pics to show.
    Some shaving and cutting occurred. Is there a remedy for this wound by the shop cutting the wheel well guard - - by the fog lights? Do you mind you showing your cut and remedy
  2. Feb 8, 2017 at 8:34 PM
    Can always purchase some and re-tap it in
  3. Feb 8, 2017 at 8:37 PM
    Les7311
    have any pic to show @ Sean? Searched the forum for fixes but could find any particular posts / threads / pics
    I do believe that a 6 inch lift is the way to go.....
  4. Feb 8, 2017 at 8:56 PM
    You talkin bout well guard liner front of tire???
  5. Feb 8, 2017 at 8:57 PM
    Post up pix when u can to confirm we are on the same page
  6. Feb 8, 2017 at 8:58 PM
    I bought used '14 CM that came with a RC 6" the liner's in front of tire were cut cause of rubbing
  7. Feb 8, 2017 at 8:59 PM
    Forgot to add...truck came with 35s
  8. Feb 8, 2017 at 9:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This??
  9. Feb 8, 2017 at 9:46 PM
    TheBeast The Beach
  10. Feb 8, 2017 at 10:24 PM
    csuviper
    Broomfield, CO
    Roman likes this.
  11. Feb 9, 2017 at 2:01 AM
    Les7311
    IMG_0829.jpg Everyone is correct.... all those pics are my surgery scars..the plastic plastics and not the actual bumper... snifff sniff.
    Am taking poporaZi pics like no tomorrow - posting soon. Any fab-up cures anywhere?
    Driver side surgery. Told the installer I want a "clean cut",
  12. Feb 9, 2017 at 2:40 AM
    I'll take pics later after work 6" RC lift with 35s no cuts on plastic even retain front small mud flaps
  13. Feb 9, 2017 at 4:11 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Idk how much extra room you need but when I fixed mine I unscrewed the bottom and pushed them until they were as far as they could go and still put a screw back in the bottom. I probably gained 2 inch clearance. I'm not a fan of the cut/missing front fender liner. If pushing it doesn't work then you'd have the cut the whole damn bumper, that's how flush mine are.
  14. Feb 12, 2017 at 7:20 AM
    Dgoll75
    Dgoll75 New Member
    Mine only rubbed slightly in reverse. Trimmed it the same way as yours looks. As clean as possible with a dremmel and resolved the issue.
  15. Feb 21, 2017 at 3:40 PM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    You guys are mentioning "pushing" the fender liner up.
    How are you "pushing"? Are you heating with heat gun?
  16. Feb 21, 2017 at 4:24 PM
    Les7311
    Curious also......hope to fab up a fix during the spring.
  17. Feb 21, 2017 at 4:25 PM
    I loosened the bolts that hold the front number end cap n pushed it forward away from tire then added to small self tap screws to mud flap to other plastic piece and the flap is forward more so that tire don't rub
  18. Feb 21, 2017 at 4:31 PM
    KIMG0511.jpg KIMG0512.jpg KIMG0509.jpg KIMG0508.jpg see those two additional screws I screwed em to that other plastic piece and it pulled the flaps away from tire
  19. Feb 21, 2017 at 4:42 PM
    Les7311
    Are you wearing 20 x 35's?
  20. Feb 21, 2017 at 5:07 PM
    35x12.50x20 Toyo at 2
  21. Feb 21, 2017 at 6:30 PM
    Les7311
    Wow. I guess you invented the recipe to not get "cut". But then again you have a 2014 and TOY could have twequeed the fender a bit based from complaints. Maybe????
