Why are wheel spacers necessary with Coachbuilder TRD Pro kit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jmcv, Jan 10, 2023.
  1. Jan 10, 2023 at 8:56 AM
    Jmcv
    Jmcv [OP] New Member
    2019 trd pro
    Can anyone tell me why it's necessary to use wheel spacers with the TRD pro coachbuilder lift kit?
  2. Jan 12, 2023 at 5:55 PM
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    It's for if you're running factory wheels with the lower offset. If you get a set of aftermarket wheels with the proper specs the spacers are not required. Pic for attention. #nospacersIMG20220617160551.jpg
    RustyShackle323 and bulldog93 like this.
  3. Jan 12, 2023 at 6:09 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Are those angled sliders?
  4. Jan 12, 2023 at 6:17 PM
    Jmcv
    2019 trd pro
    I know about the 60 offset.
    But if you don't use spacers with the tires rub?
    I have Maxxis RAZR 295 70 18 which are 34.5 x12.
    Wanted to know what I have to do so they will fit..
    Lots of people on here say they use that size tire without any rubbing issues on the TRD pros.
  5. Jan 12, 2023 at 6:21 PM
    Jmcv
    2019 trd pro
    Also some people say spacers will make rubbing worse.
  6. Jan 13, 2023 at 7:24 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    It's to avoid potentially rubbing the UCA, when you add caster to the suspension it increase the chance of your tires touching the UCA during hard turns/reverse , specially if you run wider tires, so the wheel spacers is there to eliminate the chance if you run stock wheels.
    BUT, it may not rub, it's kinda tire dependent,
    WFD473 likes this.
  7. Jan 13, 2023 at 7:31 AM
    Jmcv
    2019 trd pro
    Ok thanks now it makes sense. Thank you for the help.
    I think these Maxxis RAZRs are wider than most 295 70 18 s. I'll have to see..
  8. Jan 13, 2023 at 8:06 AM
    Downytide
    GTA
    You can always sell them very quickly here if you decide not to use them, they definitely make the truck look "right".
    WFD473 likes this.
  9. Jan 13, 2023 at 9:46 AM
    Jmcv
    2019 trd pro
    I'm going to get them on.
    Just trying to figure out what exactly I need to do that.
    I was thinking coachbuilder kit for the TRD pro. However I'm a little hesitant seeing how I emailed them twice now without any response.
  10. Feb 19, 2023 at 3:41 PM
    Petergoose1
    Petergoose1 New Member
    2020 pro army green
    Give David a call. He has answered almost every time I've called (a dozen or more.) Made the mistake of using westcott on the front. The ride is harsh, bumpsteer, and wanders pretty bad- getting rid of that garbage and putting CB on
    GODZILLA likes this.
  11. Feb 19, 2023 at 3:47 PM
    David is busy. Call him. He's 100% trustworthy.
  12. Feb 24, 2023 at 9:07 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    The exact reason for it, and this is coming from David, is that the coachbuilder steering kit will rub on the oem wheel due to the massive offset the oem wheel has. The steering knuckle will hit the wheel. If you dont install the upgraded steering kit, you dont actually need spacers if you stick with a normal (close-ish to oem) tire size. Once you go big, without a spacer you are gonna rub the UCA.
