Why are some members hesitant to go Uni-ball?
Discussion in 'Suspension' started by mrburns05, Oct 15, 2018.
  1. Oct 15, 2018 at 12:24 PM
    mrburns05
    mrburns05 [OP] New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    im just getting my research done here before I spend money... I’m wanting to get fox 2.5 coil overs and have been eyeballing those Camburg control arms, but I’ve read a few comments here and there of some of you who either were trying to avoid Uni-ball applications or weren’t happy with them for reasons I am unaware, so I was hoping you guys could chime in on the cons?
    Mountun Goat and 831Tun like this.
  2. Oct 15, 2018 at 2:15 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Camburg in particular induces A LOT of caster. I had a set and switched to MCM which is in the middle, caster wise, between TC and Camburg. Uni balls aren't 100% maintenance free thought the maintenance is minimal. I have to wipe/ wash mine after wheeling or they will be a little noisy. In the road salt areas you've got a uniball exposed to all the grime. I imagine they'd need to be cleaned pretty frequently.
  3. Oct 15, 2018 at 2:20 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Cause I don't want to cut one off :D
    MDHinSD, Trooper2, porkitt and 15 others like this.
  4. Oct 15, 2018 at 2:23 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I don't have anything against the Uniball, but I do prefer the SPC UCAs. More adjustability and a sealed joint.
  5. Oct 15, 2018 at 2:36 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Uniballs require more maintenance and many are afraid or don't want to deal with it. I have 15k on my TC UCA's without any issues, but I also clean and lubricate the uniballs after each off-road adventure. Did the same on my FJ and had no problems. Not running dust caps or uniball covers.
  6. Oct 15, 2018 at 2:51 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I went with the SPC UCA's because my research here and elsewhere on the net showed it required less maintenance than the uni-ball. I suspect the uni-ball has other features which may make it more desirable for some folks though.
  7. Oct 15, 2018 at 2:52 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Because 2 balls produce more sperm, anyways some are worried of the maintenance required but I hear it’s easy. I’m saving for uniballs, TC specifically
  8. Oct 15, 2018 at 2:54 PM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Pshhh, everyone knows that pee is stored in the balls. :rofl:
    MDHinSD, Trooper2, Darkness and 2 others like this.
  9. Oct 15, 2018 at 2:55 PM
    Gibo244
    Gibo244 New Member
    KG
    Maui
    Maintenance , not “sealed”.
  10. Oct 15, 2018 at 3:07 PM
    mrburns05
    Jacob
    Menifee CA.
    I don’t think I’ll have an issue with maintenance, one of my favorite things about the truck is keeping it maintained, with the Fox shocks I would plan to set them at +3” lift, so I think the Camburg’s extensive caster may be beneficial since I’m not doing a spindle lift? I’ll be putting the Deaver mini pack and slightly larger shackles in the rear to get it level with that setup
    Edit: thank you everyone for your input
  11. Oct 15, 2018 at 3:13 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I run Fox 2.5’s with Camburg UCA’s and haven’t had any issues. Seems a little tight at full turn but that’s it. Light cleaning and tri-flow lube.
    Darkness and mrburns05[OP] like this.
  12. Oct 15, 2018 at 3:17 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    :rofl::rofl::rofl:
    MDHinSD and Darkness like this.
  13. Oct 15, 2018 at 3:59 PM
    :facepalm:
    Darkness likes this.
  14. Oct 15, 2018 at 6:17 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    For those running the spc’s, how close are they in size to stock control arms? I’ve heard they were basically the same size, which would limit the size of the tire you could run wouldn’t it?
    Mountun Goat likes this.
  15. Oct 15, 2018 at 7:03 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Icon delta joints are pretty much maintenance free.
    3mxdivr, 831Tun, Sunnier and 2 others like this.
  16. Oct 15, 2018 at 7:06 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’m running 35x12.5” with my spcs and have about a half inch of room. Not much no.
    The reason I chose spc with the balls instead of unis is because there’s a lot of winter and salt where I live. No boots and grease equal no good. :facepalm:
    bigzrs01[QUOTED] likes this.
  17. Oct 15, 2018 at 7:07 PM
    But enough! :thumbsup:
  18. Oct 15, 2018 at 7:08 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Indeed! Haha
    bigzrs01 likes this.
  19. Oct 15, 2018 at 7:26 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Awesome so no rubbing or contact with the tires? Was debating on these vs TC
    Mountun Goat[QUOTED] likes this.
  20. Oct 15, 2018 at 7:31 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    No sir no issues yet. A lot of peeps are weary of losing alignment of spc’s if wheeling hard. I’ve wheeled the piss out of mine so far. Got a few inches of air and didn’t lose alignment. I’m a fan so far.
    Sunnier, Watt maker and Black Wolf like this.
  21. Oct 15, 2018 at 7:39 PM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
    I heard about a guy that had an accident with an auger and now he has got a bad limp and a uni ball.
    MDHinSD, Black Wolf and Mountun Goat like this.
  22. Oct 15, 2018 at 8:09 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Too bad they only come in Icon arms.
  23. Oct 15, 2018 at 8:11 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They’re good with the billets.
  24. Oct 15, 2018 at 8:21 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Most hesitant guys live in areas where there is snow and salty roads. You're in Menifee, not a problem for you.
    I put Camburg uniballs on my truck in 2010 when I lived in Riverside. They've done around 130k miles since then and barely at the point where it's time for new bushings and balls. It's easier than swapping a ball joint but a bit more expensive of a part. 8 years until next replacement doesn't bother me a bit.
    They will make some hilarious noises for the first few days, just remember you spent good money for those sounds but it goes away.
  25. Oct 15, 2018 at 11:32 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    50C0BED0-1328-49EE-A442-A65493181836.jpgThese Icon Arms have been great but I haven’t even had them for more then 1000 miles
  26. Oct 16, 2018 at 12:55 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    spc's with 37s. aftermarket wheels. snow belt.
    Mountun Goat, Black Wolf and bigzrs01 like this.
  27. Oct 16, 2018 at 1:01 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Beautiful.
    Pics?? Lol
  28. Oct 16, 2018 at 1:34 PM
    Bailey
    CO
    Considering installing the delta joint in my TC arms when the uniball is done. Probably won't be for another 2-3 years. Will be interesting to see high mileage vehicles with the delta joint.
    Black Wolf and 831Tun[QUOTED] like this.
  29. Oct 16, 2018 at 4:31 PM
    Hams
    Hams New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    Anyone run SCS wheels with Camburg uniball uppers? According to Camburg site max backspacing with these arms is 6”, SCS wheels are right at that distance. Going for 34” tires.
    Thanks,
    Joel
  30. Oct 17, 2018 at 4:53 PM
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    There shouldn't be any issues with our wheels with any brand of UCA.
