Who recalibrated for 285/70s?
Discussion in 'Wheels & Tires' started by BluegrassPro, Apr 4, 2021.
  1. Apr 4, 2021 at 5:09 PM
    BluegrassPro
    BluegrassPro [OP] New Member
    Jeff
    2021 TRD Pro
    I know there’s a lot about these tires but I was wondering who recalibrated their speedo for this size or just left it alone ? Thanks. Trying to decide between 275/70 and 285/70
  2. Apr 4, 2021 at 6:59 PM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    I didn’t....and I probably should, I’m always over the limit anyways.
  3. Apr 4, 2021 at 7:11 PM
    BluegrassPro
    Jeff
    2021 TRD Pro
    What size tires do you run? The 285/70?
  4. Apr 5, 2021 at 7:49 PM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Yeah
  5. Apr 5, 2021 at 8:06 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I have the 285/70 and I haven’t, its been pretty accurate on the speed radar that’s on the side of the road when i drop my little girl at school, but then im only going 15 mph.
  6. Apr 5, 2021 at 8:26 PM
    BluegrassPro
    Jeff
    2021 TRD Pro
    Any rubbing or issues with 285/70?
  7. Apr 5, 2021 at 8:27 PM
    BluegrassPro
    Jeff
    2021 TRD Pro
    Any issues with rubbing or tire size?
  8. Apr 5, 2021 at 8:31 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I wouldn’t think it’s worth it.
  9. Apr 5, 2021 at 8:36 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'm exactly 5% over, easy to calculate and pretty minimal increase usually so not worth it imo
  10. Apr 5, 2021 at 8:39 PM
    BluegrassPro
    Jeff
    2021 TRD Pro
    Do you have any rubbing issues with this size ?
  11. Apr 5, 2021 at 8:39 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    285/70/17’s no recal. Radar
    Signs have been between 1-2mph off. No rubbing at all. But they were stock size with Rock Warrior trim so didn’t expect anything out of ordinary. I think from what I’ve gathered on the 18” it wasn’t an issue .
  12. Apr 5, 2021 at 8:40 PM
    snivilous
    SW UT
    I barely rub the sway bar/shock resi at full turn, haven't noticed any rubbing anywhere else even when flexed. I'm on stock wheels though
  13. Apr 5, 2021 at 8:41 PM
    BluegrassPro
    Jeff
    2021 TRD Pro
    Ok yea I’m keeping stock wheels too. What kind of suspension you have? Wondering if the stock pro will be ok
  14. Apr 5, 2021 at 8:56 PM
    Ely010606
    SPARKS, NV
    There was at the beginning at full lock, all i did was use a heat gun to push the plastic back , very little though.
  15. Apr 5, 2021 at 9:02 PM
    BluegrassPro
    Jeff
    2021 TRD Pro
    Oh ok. That’s not bad! Do you have any kind of a lift? Or mods to the suspension to fit them?
  16. Apr 5, 2021 at 9:06 PM
    Ely010606
    SPARKS, NV
    i have the King’s 2.5 with the adjuster front and back and SPC UCA.
  17. Apr 5, 2021 at 9:13 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    I have 285/70/18 and I recalibrated my speedo after a year because it was annoying me. I’ve heard they don’t actually fix your odometer though.
    edit: My radar has gps speedometer and it was 5mph off.
