Who has the Tuffy Security console?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JH5370, Mar 17, 2017.
  1. Mar 17, 2017 at 4:38 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
  2. Mar 17, 2017 at 6:03 PM
    NC_Nole
    NC_Nole New Member
    Paul
    '17 Platinum MGM 4x4
    I have the Lock'er Down and love it. It fits perfectly and its really secure. I paid ~$250 and the peace of mind it gives is well worth it. I'll post some pictures if you're interested.
    Any way you choose to go its a smart and responsible choice to protect your CCW, if that whats it for of course.
  3. Mar 17, 2017 at 6:29 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    I highly recommend the Lock'er Down.
    MotoTundra likes this.
  4. Mar 17, 2017 at 8:51 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    I will be using it for my registration and my garage door opener while I am at work. My gun usually never leaves my body but if I have to go into the post office or eat dinner in the "bar" section of a restaurant it would give me piece of mind. I like the lock'er down but I like that the tuffy is smaller. Can you fit stuff on top of the lock'er down with the console shut?
  5. Mar 17, 2017 at 9:16 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Yes i keep a couple of day planner binders and some pens in there on top of my Locker Down...maybe an inch thick or so.
    Looks like the Tuffy is just a "lid" that screws into the plastic console sides?
    The Lockerdown is a steel case and the fit and finish is second to none.
    I also have the Lockerdown under seat steel safe too.
  6. Mar 17, 2017 at 9:20 PM
    Cat3ILS
    The Lock'er Down's lid is spring loaded so you can leave it unlocked and it will swing up when you open the arm rest then just lock it when needed. It's a true safe and it's built like a tank. The lock mechanism is good because the lid fits between two parts of the frame and the lock pins all three together.
  7. Mar 17, 2017 at 10:14 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    Thanks for the pictures! After reading a review stating the tuffy is just a lid I was a little weary. What's involved in installing the lockerdown? I want to minimize holes in my new truck.
  8. Mar 17, 2017 at 10:17 PM
    Cat3ILS
    It comes with two bolts. You unscrew the existing ones in the bottom of your console, drop in the safe and put the provided bolts back in the holes. It needs the new bolts because they are longer. There are no holes to drill. 10 minute install max including finding the tools in the garage.
    happyjack87 and JH5370[OP] like this.
  9. Mar 17, 2017 at 10:20 PM
    Cat3ILS
    And yes, you still have access to the power port in the console. The safe has a cut out for it.
    happyjack87 likes this.
  10. Mar 18, 2017 at 12:33 AM
    Tj6818
    Tj6818 New Member
    TJ
    I have the Tuffy Box. I love it and it is very secure. It is installed by removing the 4 bottom bolts and place the tuffy box insert inside of console. Very easy install
    JH5370[OP] and PMG like this.
  11. Mar 18, 2017 at 3:03 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    Where you get it for $250??
    Tiamat likes this.
  12. Mar 18, 2017 at 4:18 PM
    NC_Nole
    NC_Nole New Member
    Paul
    Directly from Lock'er Down. They had a sale at the first of the year.
  13. Mar 18, 2017 at 4:22 PM
    McReef
    McReef '17 Tundra TRD Pro Crewmax
    Eastern MA
    Third the LockerDown. Absolutely perfect fit, super easy install, cool and convenient spring loaded lid, and beefsteak build quality. Worth every penny.
    FWIW, I got the high security lock, and feel more secure having done so. All of the other lock versions are fairly easy to defeat (relatively speaking).
    Patriot likes this.
  14. Mar 18, 2017 at 4:30 PM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    I have the Console Vault which seems to be real close to the other manufacturers. Installation would have been a breeze (5 minutes)except two issues:
    1. One of the bolts holes was not drilled correctly and was approx 1/4 inch off - Fixed by reaming it out with my drill
    2. The bolt they provided broke while i was installing it - Supposed to be high grade bolt (Fastenal) ,but you can tell it was Chinese cheap knock off. Went to lowe's and purchased better grade of bolts.
    Now it comes with 2 holes drilled out ( towards shifter) and it seems strong enough but i decided while i was reaming out the other hole i might as well drill out two holes in the back of the console vault so that my console has 4 bolts holding it( Yeah over kill) .
    Fits like a glove- could not be happier.
    Access to power plug.
    Overall I love it.
    Bad part for me is when you hit a bump occasionally the lid will bang , but you get used to it soon.
    $240.00 if you order from them directly.
    http://www.consolevault.com/Toyota-Tundra-2014--2016_p_103.html
    If i can figure out how to post pix I will update this.
  15. Mar 18, 2017 at 5:01 PM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Here is a couple of pix .. Sorry if pix are big, cant figure out how to shrink them without degrading image.
    20170318_190224_b3aa607eaa2895dbc2034809fbf5c9158fabbce4.jpg 20170318_190159_9af3de4b537e046956b97fc92a2e82365a24015d.jpg
  16. Mar 18, 2017 at 10:56 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    Can you post some pictures? I read that it was just a lid. From your description it sounds like it's installed from the bottom.
  17. Mar 19, 2017 at 12:01 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    When you open the stock center console, there's a little sheet sitting on the floor of it. Remove that and you'll expose the bolts. Unthread bolts. Drop in new security console. Thread bolts. Done.
    JH5370[OP] likes this.
  18. Mar 19, 2017 at 2:46 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
  19. Mar 23, 2017 at 7:34 PM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Yeah, looks like the one Patriot has is exactly like the console vault.
