Who has sliders and skids in stock?
Discussion in '2.5 Gen Tundras (2014-2021)' started by wexttxco, Sep 24, 2021.
  1. Sep 24, 2021 at 7:41 AM
    wexttxco
    wexttxco [OP] New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Found: Ironman 4x4 America, Bought and shipped already!
    Hey everyone,
    Trying to get prepared for an overlanding trip in early November. I want want install full skids and sliders before I go. Problem is everyone has a long lead time. I'm not interested in waiting months, I need something that's in stock now. Looking to purchase in 3 days. Any leads? PM is fine as well.
    Thanks!!!
    Blasterrr likes this.
  2. Sep 24, 2021 at 10:44 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I got my transmission/transfercase/cat skid from Talon's Garage, Shaun shipped it out in 2 days.
    wexttxco[OP] likes this.
  3. Sep 24, 2021 at 10:45 AM
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro (Should’ve kept it) Mudbath TRD Pro
    SDHQ was pretty quick. I ordered in July and they showed up less than a week later.
  4. Sep 24, 2021 at 11:32 AM
    wexttxco
    21 SR5 DC 4x4
    Thanks for the leads. Talon is out of stock, skid plates at SDHQ all mention extended lead time, but their sliders just might be in stock, I'll call Monday to ask.
  5. Sep 24, 2021 at 12:28 PM
    wexttxco
    21 SR5 DC 4x4
    Sdhq is checking on lead times.
    If I buy a stock trd pro skid on ebay, will it be compatible with other skids as well? That would at least get me coverage for the oil pan, though I need some darn sliders or I might have to cancel my trip.
  6. Sep 24, 2021 at 12:43 PM
    2mchfun
    I would have a welder fabricate some if you aren't able. Personally, I am going to fabricate my own by running 4" channel Iron, channel facing down from one side to the other so I can also protect converters and trans at the same time. Weld a plate on top of front channel for transmission and a expanded metal screen on rear channel for the converters. Then add 3" x 1/4" equal leg angle as the sliders/steps. My current step tubes will simply bolt directly on top of the angle. So, the truck will actually be sliding on the edge of the angle 3" below the bottom of the step tube. Plus I will have great t-bone protection and the entire frame will be stiffened.
  7. Sep 24, 2021 at 12:58 PM
    wexttxco
    21 SR5 DC 4x4
    Thank you. Not sure if that's an option but I'll ask around.
    Probably buying the trd pro skid plate since nobody else has one in stock.
    2mchfun likes this.
  8. Sep 28, 2021 at 6:04 AM
    wexttxco
    21 SR5 DC 4x4
    Skids are taken care of, had some leads on sliders and they fell through, other than driving from Texas to California to have a set installed which I can't do.
    Anyone else?
  9. Sep 28, 2021 at 6:20 AM
    2mchfun
    Hit some industrial machine shops in your area and ask them to fabricate you a set. A trailer builder or repair place would also be a safe bet to try.
    wexttxco[QUOTED][OP] likes this.
  10. Sep 28, 2021 at 6:21 AM
    2mchfun
    Did you check SDHQ?
  11. Sep 28, 2021 at 6:22 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    I second just asking a local fab shop to make you some, odds are it isn't their first pair and it'll be cheaper. I got a quote from a shop near me to make some for only $700 and is every bit as good as any other. SDHQ is way overpriced although a good product.
  12. Sep 28, 2021 at 6:45 AM
    wexttxco
    21 SR5 DC 4x4
    Thanks. Sdhq never returned to me with lead times after the hassle of holding for a ton of time so I stopped considering them.
    The problem is I live in a small truck stop town, we have a couple of ranch welder type shops I'll check with, but I fear I'd end up with a crappy cold rolled steel pipe slider set even though if ask for DOM. No pipe benders.
    El paso is a couple hours drive. I'll start researching for shops there that can help me out, and I'll ask around at work.
    And just in case I'll continue my search to find a set in stock.
  13. Sep 28, 2021 at 6:46 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Call @Caliraisedled and see if they are doing a run any time soon, or if they have some laying around. They’re based in Fort Worth and if you’re in Texas you can pick them up.
  14. Sep 28, 2021 at 9:54 AM
    wexttxco
    21 SR5 DC 4x4
    8-9 weeks a Cali Raised as well. These lead times are crazy.
  15. Sep 29, 2021 at 2:07 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    Demello All-pro?
  16. Sep 29, 2021 at 2:29 PM
    wexttxco
    21 SR5 DC 4x4
    Ironman 4x4 America actually had skids and sliders in stock so I purchased them. thanks everyone!
    Blang805 likes this.
  17. Sep 29, 2021 at 5:33 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    All pro off road
  18. Nov 6, 2021 at 11:47 AM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Hey, How are you liking the Ironman sliders? I was thinking of getting some and just curious on your thoughts and pros and cons. Easy to install?
  19. Nov 6, 2021 at 3:54 PM
    wexttxco
    21 SR5 DC 4x4
    Haven't installed them yet, and they literally don't have instructions for them. Like, figure it out on your own is the instructions. Supposedly they will make a YouTube video soon showing the install, but still haven't seen it. So immediately was turned off by the "figure it out" approach. The skids didn't come with instructions either, but they at least had an instructional page to email me.
    Sliders shouldn't be too difficult since they claim no drilling, but with 30 sets of fasteners, I haven't attempted it yet. Have to get them installed the next few days so I'll follow up afterwards.
  20. Nov 6, 2021 at 3:55 PM
    wexttxco
    21 SR5 DC 4x4
    So, not super impressed with the company to start out, and TBD if the pieces are up to par, they seem well made, though.
  21. Nov 6, 2021 at 4:46 PM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Hm, okay well I just ordered them so lets hope they are good! I will very much be looking forward to your thoughts on them, I smashed my factory side steps up into the body of my truck this summer and would prefer that never to happen again. I also wanted a good jack point for a hi-lift
  22. Nov 6, 2021 at 5:07 PM
    wexttxco
    21 SR5 DC 4x4
    I'll let you know if I end up with any tips or problems to pass along
  23. Nov 24, 2021 at 3:34 PM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Hey did you get them installed? Or could you send the instructions you got from them? I’m super confused it’s just a giant bag of bolts with no guidance at all. Thanks so much for any help!!
  24. Nov 24, 2021 at 5:13 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Lol that’s nothing. WKOR sliders were almost 12 weeks+.
    Unless if you really need it this very weekend, you’re going to have to see some long lead times regardless.
  25. Nov 24, 2021 at 6:06 PM
    wexttxco
    21 SR5 DC 4x4
    No instructions are available, and they aren't bolt on with newer tundras, frame needs to be drilled. I haven't installed them yet.
  26. Nov 25, 2021 at 6:59 AM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Oh fun! Well thanks for the reply and I guess this weekend I’m in for some drilling and frustration!
  27. Dec 21, 2021 at 9:29 PM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Okay got the Ironman sliders on! It really wasn’t bad they bolted right up without much drama. Good quality and I like the look for the price and ease of installation. Yes if you want to use all of the provided bolts and hardware you will have to drill some holes in the frame for upwards bolts. Otherwise I got probably 6 bolts in on each side without drilling and it feels solid. Happy to answer any questions but overall it was easier than I expected
  28. Dec 22, 2021 at 6:02 AM
    wexttxco
    21 SR5 DC 4x4
    I wonder what the frame differences are with 21 models, I could only get 3 bolts on each side
  29. Dec 22, 2021 at 8:36 AM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Yea I’m not sure, I would think it’s exactly the same as my 2015? I did have them on the wrong side at first but I could barely line up any when I did that. Did you have it too far forwards or backwards? I had to remove a few brackets in the rear of the drivers side and then you reuse the bolts you remove from the brackets for mounting the sliders. They provide a couple small bolts and nuts for the same spot on the passenger side as it’s not threaded holes like the DS.
