White smoke
Discussion in '1st Gen Tundras (2000-2006)' started by JPM, Jun 28, 2019.
  1. Jun 28, 2019 at 1:44 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    2005 Tundra SR5 4.7 v8
    3” leveling kit. 33s. AR wheels.
    Did any of you guys have issues with 2005 4.8 blowing white smoke? It’s not all the time but more often then it should.
  2. Jun 28, 2019 at 1:54 PM
    BEERS
    BEERS New Member
    2018 MGM Tundra Sport
    Toytec Boss Lift, Stuby ant, Clear bra, Remote start, Tinted windows, Console Safe, ABS Protectors and LED Cargo, reverse and brake lights
    White smoke is coolant burning. Most common thing is head gasket leaking
    GNTundra and Sunnier like this.
  3. Jun 28, 2019 at 2:12 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    That’s what I figured. I was hoping it could have been something else.
  4. Jun 28, 2019 at 2:19 PM
    BEERS
    BEERS New Member
    You can pressure test to see where the leak is. It helps if the engine is at operating temp. If it is a head gasket u can pull spark plugs to see which cylinder is burning coolant
  5. Jun 28, 2019 at 2:30 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    I don’t see any coolant mixed with the oil. And no it has not o we heated.
  6. Jun 28, 2019 at 2:31 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    Thanks for the suggestion to test it.
  7. Jun 28, 2019 at 2:43 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    White smoke means there's a new pope. Isn't that how it works?
  8. Jun 28, 2019 at 2:44 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    And I thought this was a bbq thread lol
  9. Jun 28, 2019 at 3:48 PM
    Aerindel
    Aerindel New Member
    Montana
    Are you sure it’s smoke or just condensation in cool wet weather? I’ve had people freak out before over white smoke when starting cars in cold weather when they aren’t used to it.
    Britrider750 likes this.
  10. Jun 28, 2019 at 3:55 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    I’m sure. It blowing out white smoke from the exhaust. And then after a few seconds it stops.
  11. Jun 28, 2019 at 4:09 PM
    Professional Hand Model
    Hand Protectors
    Cold Start up? Then white smoke for few seconds? Then stops smoking?
    Aerindel likes this.
  12. Jun 28, 2019 at 4:34 PM
    Aerindel
    Aerindel New Member
    Montana
    Yeah...this is an important question.
    A few seconds of white smoke that only happens after its been sitting could be something as simple as a leaking fuel injector or valve seal.
  13. Jun 28, 2019 at 6:59 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    So it happens at cold starts and some times at Operating temp starts. For example, I drive to the store and it sits for 10 minutes then it will happen.
    Also it smokes for a few seconds then stops but sometimes it won’t stop until a few seconds of driving.
  14. Jun 28, 2019 at 7:02 PM
    Hand Protectors
    How many miles on the truck?
  15. Jun 28, 2019 at 7:18 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
  16. Jun 28, 2019 at 7:53 PM
    Hand Protectors
    Service history?
  17. Jun 29, 2019 at 1:46 AM
    Aerindel
    Aerindel New Member
    Montana
    So it's always on starting after sitting.
    Are you loosing coolant or oil?
    Head gaskets can fail in many different ways but usually you notice leaking coolant or overheating first.
    Is there any smell to this smoke? A sweet smell is coolant, a burning rubber smell is oil.
    Leaking valve stem seals will leak a little oil into a cylinder when sitting that burns off as soon as you start it. A leaking fuel injector can do the same thing but with fuel but usually causes running problems as well.
    And a cracked block or headgasket leak can leak coolant for the same effect, although you usually then have noticeable coolant loss and or overheating.
  18. Jun 29, 2019 at 4:58 AM
    JPM
    JPM [OP] New Member
    Charlotte NC
    It was not taken care of. The truck is new to me but the guy before never did anything. So I’m in the process of clean up. There was gunk in the motor and probably still is. Lots of carbon build up. So I’m in the process of all of that. I thought the white smoke was due to the seafoam but I stopped using for a little to see if it goes away and it hasn’t.
  19. Jun 29, 2019 at 5:34 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My truck produces some very light "smoke" after start up but I determined it to be condensation after doing research. When it's thicker white smoke and continues after its warm, that's more concerning.
    In addition to the compression test, you can send in an oil sample to Blackstone labs and they can look for coolant in the oil.
  20. Jun 29, 2019 at 5:41 AM
    JPM
    JPM [OP] New Member
    Charlotte NC
    Thanks for your input!
  21. Jun 29, 2019 at 5:51 AM
    Hand Protectors
    You could run some High Quality Synthetic Oil and change the oil and filter at 2k intervals to clean out any sludge. The carbon can be cleaned off your throttle body. Put in some new plugs and coils and new air filter. Basically, do an all around tune up.
  22. Jun 29, 2019 at 6:07 AM
    JPM
    JPM [OP] New Member
    Charlotte NC
    That’s what I started with. I have changed the plugs but not coils yet. I put the seafoam I. The throttle body but have not actually cleaned the throttle body yet. So I’m chipping away at it little by little.
    Thanks for all your help.
  23. Jun 29, 2019 at 8:41 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I know Acapulco Gold, Purple Haze and few other colors but White Smoke?
    Ohhhh wait, you talking about your truck. Damn
    bmf4069 likes this.
  24. Jun 29, 2019 at 8:47 AM
    Hand Protectors
    Yeah the research leads to badness on this one sadly. Consistent white smoke doesn’t look like an easy quick fix already stated by the above posters.
  25. Jun 30, 2019 at 6:37 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    If you're concerned the white smoke is related to a head gasket issue/burning coolant, you can start the truck and then get out and get a whiff of it. Burning coolant has a very obvious smell to it.
    More often then not it is just condensation. Keep an eye on your coolant levels and engine temps.
  26. Jun 30, 2019 at 2:20 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    Thanks. I will do that and see if I can smell it.
  27. Jun 30, 2019 at 2:40 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Mine has a puff of smoke once in a while white in color/blueish, but smells of oil. Very common. There is an oil catch can post online to catch and hold the oil before it goes in the PCV system.
    Filthyphil likes this.
  28. Jun 30, 2019 at 2:48 PM
    JPM
    JPM [OP] New Member
    Charlotte NC
    Good to know. Thanks.
  29. Jul 18, 2019 at 10:31 PM
    Dblwoof
    Dblwoof New Member
    Worked to death then resuscitated wrinkly blotched silver skinned '00 Tundra
    Custom skinned : fenders, doors, rear quarter panels, and tailgate. High flow front grill. Custom paint and decals. Completely bone stock sitting on some decent rubbers. Aftermarket lighting.
    How's your power steering fluid? Have you checked it recently? I am only asking because my '00 tundra would blow a good sized cloud of white smoke every time I started it and then after a few minutes it would clear up. Turned out a seal in the switch controlled by vacuum on the power steering pump had failed and it was literally burning power steering fluid. Just thought I'd throw my two cents in there for what its worth.
  30. Jul 19, 2019 at 3:03 AM
    JPM
    JPM [OP] New Member
    Charlotte NC
    I appreciate that. Last I checked power steering fluid was fine. But I will double check.
    Dblwoof[QUOTED] likes this.
