White smoke on startup for short period - Tundra V 8
Discussion in '1st Gen Tundras (2000-2006)' started by bootheg001, Mar 4, 2020.
  1. Mar 4, 2020 at 11:59 PM
    bootheg001
    bootheg001 [OP] New Member
    Changed valve stem seals. Smoking worsens.On startup,engine revs at 2200 rpm for a short duration after which the white smoke disappears after the engine rev falls. Mechanic suggests rings need changing. Engine mileage only 100,000. Any comments?
  2. Mar 5, 2020 at 3:43 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    100K is really low mileage for worn rings. A compression check would tell you a lot. A leak-down test would tell you even more. Without one of those test, it's impossible to diagnose rings as the problem.
  3. Mar 5, 2020 at 5:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You sure it's actual smoke and not just a bit of condensation being blown out during a cold start?
  4. Mar 5, 2020 at 6:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    White "smoke" is not oil, and your "mechanic" knows that. Burned oil in exhaust smoke is blue. It could be condensing water vapor as suggested, or it could be coolant leaking past head gasket. In my paranoid opinion, mechanic has nicked you for the valve seals, now he's trying to get you over the barrel again for a complete tear down. Find another mechanic.
  5. Mar 5, 2020 at 8:49 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    FWIW, my used to do that every now and then. Cleaned the throttle body and have never seen it since.
    abcinv likes this.
  6. Mar 5, 2020 at 8:58 AM
    Cthulhu
    Agreed, white smoke might be a head gasket...
  7. Mar 5, 2020 at 9:10 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    If it's a bad head gasket, you'll see a drop in the coolant level. You might also see some contamination from combustion particles getting into the coolant. Mine does the same thing and you can see clear water at the end of the tailpipe. It's condensation that forms as the system cools down. Once it's warmed up, there's no steam (it's not really smoke) and no problem with fluid levels. I, too, believe that the major problem here is that your mechanic is either incompetent, crooked, or some combination of the two.
    JohnLakeman, PCJ and Filthyphil like this.
