White Mist or Smoke out of AC Vents
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScarletSSpyder, Jul 16, 2019.
  1. Jul 16, 2019 at 8:19 AM
    ScarletSSpyder
    ScarletSSpyder [OP] New Member
    So a weird thing happened yesterday on my commute into work. I was in stop and go traffic for a while with the ac on (like any other day). Noticed at one point white "smoke" starting coming out of the top vents. No smell at all. It went away once I turned off the AC. Engine temp and oil pressure was fine. Turned it back on a few seconds later and no white "smoke". Used the AC on the entire way home yesterday and this morning with no issue...
    Any idea what would cause this?
    2019 4.6l 4x4. 2,200 miles.
  2. Jul 16, 2019 at 8:56 AM
    agent319
    agent319 New Member
    Stuart
    2015 Red 1794
    no mods
    If this happened when it was warm w/ high humidity out side then this can happen occasionally
    TXTundra2722 and NewImprovedRon like this.
  3. Jul 17, 2019 at 9:35 AM
    nodak67
    nodak67 New Member
    JR
    very high humidity and heat between a/c compressor cycles this can happen. will also briefly happen when you shut off the a/c. this happens more often down south. i never get this anymore being up north since i moved from georgia.
    Shanesyota likes this.
  4. Jul 19, 2019 at 5:24 AM
    xma
    xma New Member
    TX
    17 Cement CM TRD Pro
  5. Jul 19, 2019 at 6:48 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Water in the atmosphere (humidity) trying to condense in the air due to the temperature drop coming out of the vents. You will see this a lot on airplanes when they land in a hot country.
    xma likes this.
  6. Jul 19, 2019 at 6:50 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Damn old farts know everything.
  7. Jul 19, 2019 at 6:56 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    When people get my age we are happy to have farts and nothing else.. Depends has two meanings. ‘Depends’ what comes out
  8. Jul 19, 2019 at 7:33 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Some of the best convos I have are with old farts. I suppose that’s good considering I’m rapidly encroaching into their territory.
    xma likes this.
