Whistling sound when going 90 or over.
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Jan 29, 2017.
Thread Status:
Not open for further replies.
  1. Jan 29, 2017 at 2:49 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I noticed that my truck starts making a whiny whistling sound when going over 90 MPH. I noticed that it only comes from the driver front side, or seems to. I am pretty sure it is just a wind whistle(not the most aerodynamic vehicle...). Just wanted to see if anyone else has noticed this on their Tundra. I do not get any shaking or vibrating when going those speeds. So I am not thinking it is a suspension or tire problem
    I am just concerned that it could be a wheel bearing or front differential problem. However it never makes that noise unless I am going over 90 MPH. So I am leaning toward wind whistle.
    Has anyone noticed something like this when going over 90 in their truck?
    Thanks
  2. Jan 29, 2017 at 2:53 PM
    kenomouth64
    Tetrus
    ***Does not seem to make the noise when revving the motor at lower speeds.***
  3. Jan 29, 2017 at 2:57 PM
    Why are you needing to be at those speeds?
    tomsinamerica, GNTundra and Agitated1 like this.
  4. Jan 29, 2017 at 3:17 PM
    woodchuck
    woodchuck New Member
    chris
    14' Tundra Crewmax 4x4
    Its probably your mother or wife telling you to slow the HELL down! :headbang:
    7Toys4Me, SiLV3R and T-Rex266 like this.
  5. Jan 29, 2017 at 4:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Were you farting at the time? Could be from over pucker of the butt cheeks while traveling 100mph in a 3 ton truck
  6. Jan 29, 2017 at 4:38 PM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    I haven't heard it when I was going over 90. While on this high speed subject, does our truck cut off at a certain MPH? Like 104 or something? Asking for a friend.
    joonbug and T-Rex266 like this.
  7. Jan 29, 2017 at 4:59 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  8. Jan 29, 2017 at 5:02 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Humm. Turbo spooling up? Joking aside. Try and put tape where the mirror housing mates at the drivers door. Tape on the pillar and window to mitigate possibilities.
  9. Jan 29, 2017 at 5:03 PM
    csuviper likes this.
  10. Jan 29, 2017 at 5:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What he said ^^^
Thread Status:
