Whistling during throttle.
Discussion in '2.5 Gen Tundras (2014-2021)' started by arkhomer, Jan 9, 2019.
  1. Jan 9, 2019 at 9:08 AM
    arkhomer
    arkhomer [OP] New Member
    Tyler
    2024 Limited
    I am getting a high pitched faint whistling noise when accelerating. Sounds like it may be coming through air vents. Seems to be worse at highway speeds. Anyone experienced this?
  2. Jan 9, 2019 at 9:41 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Sort of seems familiar. A couple of times I've heard something I might describe that way, but not all the time.
  3. Jan 9, 2019 at 12:04 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I have a whistle but it sounds more like a turbo. It comes from my CAI. Sorry, I can't tell if I have what you have....
  4. Jan 9, 2019 at 12:06 PM
    Believe I heard from on here, this is from the screen mesh throttle body gasket
  5. Jan 9, 2019 at 2:35 PM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    Yes I had the same issue. If you will search around this forum you can find more information about it. If I recall it is the throttle body gasket. I took mine out and cut the mesh out of it, but still had the whistle sound. So I bought a throttle body gasket for the 4.7 I believe and it fixed the problem!
  6. Jan 9, 2019 at 2:41 PM
    PA452
    PA452 New Member
    So it wasn't actually a problem, just an annoyance?
    If it's just one of those things I can ignore it. I have a tendency to hear those things though and worry about what might be wrong.
    GODZILLA likes this.
  7. Jan 9, 2019 at 3:06 PM
    Tundraman479
    What I was hearing was a very high pitched whistle coming from the front passenger side.
    It wasn’t a problem it just drove me crazy lol
  8. Jan 9, 2019 at 3:11 PM
    PA452
    PA452 New Member
    Mine isn't super loud when it is there. If I have tunes playing I don't think I'd even hear it.
  9. Jan 10, 2019 at 4:24 AM
    arkhomer
    Tyler
    2024 Limited
    Thanks for the info! Found the throttle body gasket thread. I'll definitely be doing this.
  10. Jan 10, 2019 at 4:34 AM
    FYI, they (dealership) even sell the gasket without the screen mesh
  11. Jan 10, 2019 at 6:03 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Supercharger whine? :D could it be something stuck in one of the exterior vents, debris, leaves or a bunch of pine needles? If not the gasket...
  12. Jan 10, 2019 at 10:42 AM
    vanoss101
    vanoss101 New Member
    2015 SR5 Tundra DC
    Could it be the ECM hissing/humming? There are a couples thread about it on here.
  13. Jan 15, 2019 at 4:05 PM
    Tundraguy12
    Tundraguy12 New Member
    David Myers
    2015 Black Tundra TSS CrewMax
    Winjet Tails 5% Tint all around
    Supercharger you didn’t know about?
  14. Mar 2, 2019 at 3:13 PM
    Birdhunter
    Birdhunter New Member
    Scott
    2017 Double Cab 5.7 4x4 TRD
    Same problem here. I recently purchase a 2017 that had a K&N cold air intake and changed out the mesh gasket and it helped, but it still had an annoying high pitch whistle. I put the original air box bak on (came with the truck) and it still makes the noise. I’m thinking it could be the secondary air fan, but not sure of its location. I have about 1,500 miles of warranty left and would love to get this resolved.
  15. Mar 2, 2019 at 4:13 PM
    trd4life
    trd4life New Member
    2015 Black Limited CC 4x4 5.7
    2” lift 285/65/20 Nitto Terra Grapplers
    I’ve heard this from Day 1.....glad I’m not the only one that hears it too
    Only happens when you first put your foot into it
    ntg likes this.
  16. Nov 11, 2019 at 12:07 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Could somebody provide a link to the thread in question, and does anyone have the part number for the mesh-less gasket?
    Thanks!
  17. Nov 11, 2019 at 12:09 PM
    @Roman
    Roman likes this.
  18. Nov 11, 2019 at 12:10 PM
  19. Nov 11, 2019 at 12:11 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    I have just started noticing this on my 15. It’ sounds very similar to a turbo which I don’t mind at all!!! I kind of like it ha ha. Reminds me of my old duramax. As long as it is not causing me any issues I’m just going to leave it be. Mine is very faint so it’s not annoying
  20. Nov 11, 2019 at 12:21 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
  21. Nov 11, 2019 at 1:16 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I hear it in my 20 but have gotten used to it and ignore it. Reminds me of when i was 18 and a buddy of mine had a throttle body spacer on his 4.0 Ranger :rofl: It's a subtle whistle so no big deal to me.
  22. Nov 11, 2019 at 1:20 PM
    Rex Kramer
    Georgia
    Thanks, but it turns out the mesh screen is not the cause... still searching for the cause & solution.
    Airn890 likes this.
  23. Nov 11, 2019 at 3:21 PM
    Speedkills119
    Speedkills119 Shenanigator
    Ryan
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    Had the same problem. Putting in the SC fixed it, gaskets' cheaper...
    Jaypown likes this.
  24. Nov 11, 2019 at 5:12 PM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    The only time I've heard my car whistle was when a gasket had a leak.
  25. Nov 12, 2019 at 3:27 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    I've noticed the same noise on my new 2019 DC. Sounds kind of like a turbo whistle. Seems to run fine and any time the radio is on (which is about 99% of the time) you can't hear it. Kind of like it actually.
  26. Nov 12, 2019 at 1:28 PM
    vanoss101
    2015 SR5 Tundra DC
    How do you know the mesh screen is not your problem? Have you removed it?
    Rex Kramer[QUOTED] likes this.
  27. Nov 12, 2019 at 1:42 PM
    Rex Kramer
    Georgia
    Of course I removed it, how would I know if I hadn't?
    I went out and removed it right away, and then took it for a test drive.
    The whistle remains 40 mph to about 70 mph, coasting and with throttle applied.
    MaxMB likes this.
  28. Jan 6, 2021 at 5:46 PM
    TrexTundra
    TrexTundra Live Free or Die Tryin
    Trevor
    Idaho
    2017 Black Tundra Platinum
    **Work in progress** 3/1 Procomp Nitro leveling kit 285/70/18 Nitto Ridge Grapplers 18x9 Black Fuel Vapors +1 offset Led Headlight/fog lights Will be removing chrome and Plastidip black
    Just got my new (2017) Platinum. It whistles when accelerating and not gonna lie, I kinda like it!
  29. Jan 6, 2021 at 6:12 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Do you have a different intake or have you removed or is the HCF removed prior to owning it? That makes the whistle happen too...
  30. Jan 6, 2021 at 6:26 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Mine is a very high pitch squeal, similar to a dog whistle. Not pleasant at all. Seems to be right at cruising speeds, between 1500 RPM’s & 2000 RPM’s. Gonna try the mesh wire trick in the next few days and hopefully that’ll stop it. It’s very irritating.
