Whistle coming from engine
Discussion in '2nd Gen Tundras (2007-2013)' started by 2010SR5NIC, Mar 24, 2024.
  1. Mar 24, 2024 at 2:14 PM
    2010SR5NIC
    2010SR5NIC [OP] New Member
    2010 Salsa red pearl DC
    Dobinson lift front and rear, SPC UCA’S, icon add a leaf, coach builder shackles, 18x8 method wheels with 295/75 falken wildpeaks.
    2010 5.7 4x4 when accelerating from a stop there is a little whistle coming from what sounds like the passenger side of the engine. Goes away at higher rpm and higher speed. Anyone have an idea where it could be coming from?
  2. Mar 24, 2024 at 4:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you buy it new?
    I'd check the air box and see if there is an aftermarket filter in it, or see if someone took off the OEM screen in the air box lid...
    Good luck.
  3. Mar 24, 2024 at 4:30 PM
    2010SR5NIC
    no. Bought it used. Okay I’ll check that.
    1lowlife[QUOTED] likes this.
  4. Mar 24, 2024 at 4:42 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Maybe someone put one of those throttle body spacer doodads on there. They make a whistling sound. Mine whistles a bit under load but I have the SABM mod (2nd hole in the airbox), a higher flow air filter, and a blower sucking more air in.
  5. Mar 24, 2024 at 4:44 PM
    2010SR5NIC
    so I take it it shouldn’t be something I should be worried about?
  6. Mar 24, 2024 at 4:46 PM
    RobertD
    Robert
    DFW, Texas
    Do the throttle body screen delete. I bought the new screen less gasket since it was $5. Took 5 minutes of work and the whistle vanished for me
  7. Mar 24, 2024 at 4:58 PM
    2010SR5NIC
    can you post a link please?
    RobertD[QUOTED] likes this.
  8. Mar 24, 2024 at 4:59 PM
    Silver17
    Eastern PA
    I appreciate the tip, but I don’t think mine is related to that since I don’t have that screen anymore having had installed the supercharger. I think in my case, it’s just the increase of air flow and speed. Could be OPs solution though?
  9. Mar 24, 2024 at 5:00 PM
    RobertD
    Robert
    DFW, Texas
    One moment
  10. Mar 24, 2024 at 5:22 PM
    RobertD
    Robert
    DFW, Texas
    I thought there was a thread on this but I'm not finding one searching. I know inread some info about the screen delete on this thread:
    https://www.tundras.com/threads/throttle-body-coolant-bypass.55350/#post-1449073
    My 2 cents, clean your throttle body while you have it all apart. Much easier then cleaning it while its installed :rofl: I did it the hard way and then the easy way when I had it loose. I didn't disconnect the lines from the throttle body.
    OReilly's is close to me but you should be able to find an equivalent gasket at any auto store or be able to order thru them.
    https://www.oreillyauto.com/detail/...dy-mounting-gasket/mae0/g32158?q=G32158&pos=0
  11. Mar 25, 2024 at 7:01 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    My truck had a K&N filter when purchased and would whistle. Replaced the fancy, purple filter with a standard paper filter and have not had to listen to the whistle any further.
    I left the screen intact.
    2010SR5NIC[OP] likes this.
  12. Mar 25, 2024 at 7:46 AM
    2010SR5NIC
    I’ll check the filter too. Thanks!
  13. Jul 29, 2024 at 7:25 AM
    2010SR5NIC
    my truck does have the dry K&n filter. Should I replace with oem or wix or something?
  14. Jul 29, 2024 at 7:56 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    i cant believe no one dropped this gem.....
    (start at 40s)
  15. Jul 29, 2024 at 12:29 PM
    COTundie
    Trey
    Pretty things
    Either of those should be just fine.
    Seems to be a high flow filter thing.
    I didn't notice a difference in power between the two filter elements. And better filtration (more restriction) will help with engine longevity... Also no whistling on throttle.
    ....Also Also. "That's only in the morning. Should be up cooking breakfast or something"
  16. Aug 5, 2024 at 6:31 PM
    2010SR5NIC
    no throttle body spacer. I bought the throttle body o ring without the mesh and replaced it and it seemed to help. No whistle now.
    RobertD likes this.
