Whirring noise.. Help!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Evader53, Aug 8, 2018.
  1. Aug 8, 2018 at 3:15 PM
    Evader53
    Evader53 [OP] New Member
    I'm at 7100 miles on my 2018 Tundra Limited. I just finished up a 2000 mile trip, and over the last 400mi or so I developed a "whirring/whining" sort of sound.
    Its most pronounced above 68+ mph when pressing the gas lightly. Seems to go away as soon as I let off. Here is a video I took in an attempt to record the noise (as always, sound quality on a video doesn't make it sound near as pronounced as it actually is);
    *Updated video* Sound starts about 7 seconds in, and can be heard best between 16-19 seconds
    Also, since threads are worthless without pics... Here's the beaut;
    HighDesertSurfer likes this.
  2. Aug 8, 2018 at 4:04 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Nice truck.
    Hard to gear anything. Where is the sound coming from?
    Evader53[OP] likes this.
  3. Aug 8, 2018 at 4:07 PM
    Where is sound you hear might be coming from engine area, under cab area, rear end?
  4. Aug 8, 2018 at 4:19 PM
    Evader53
    I'm not able to tell where its coming from. I just uploaded a different video that captures the sound better. It starts around 7 seconds in, and is best heard between 16-19 seconds
  5. Aug 8, 2018 at 4:23 PM
    I'm guessing maybe the gasket behind the throttle body? Ther is a metal mesh screen some mememem on here have said of same noise and replaced with just only the ring gasket and noise goes away.
    Maybe someone else chime in and assit
  6. Aug 8, 2018 at 4:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Any modifications to the intake? Even an air filter or anything like that? Even if not, check everything that has to do with the intake. Make sure it’s all tight.
  7. Aug 8, 2018 at 4:31 PM
    Evader53
    I've heard of this, it just seemed odd to me that it would all of a sudden start making the noise out of nowhere after 6700 miles.
    No mods what-so-ever. It started on the last day of my roadtrip. Nothing significant about the drive either that may have caused this, the entire drive was on the highway.
    I briefly checked everything on the intake and all seemed tight. I'll check it out again. I've got an appointment with the dealer tomorrow for them to have a listen/look as well
    15whtrd[QUOTED] likes this.
  8. Aug 8, 2018 at 7:25 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I' gonna guess a belt tensioner or idler pulley
  9. Aug 8, 2018 at 9:30 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Wouldn’t that be more of a squeal??
    Buckbuck says it’s something loose on the intake system.
  10. Aug 8, 2018 at 9:55 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Is it a electrical noise around the 2100 RPM? High pitched.
  11. Aug 9, 2018 at 2:26 AM
    polymerhead
    polymerhead New Member
    Hard to tell from your video, but I noticed a soft whirring sound coming from the engine bay or dash on the passenger side of the truck. Both the truck I test drove and the truck I bought had it, so I assume it is a normal part of the vacuum system or something. I think the only reason I noticed it initially was because it was a new sound, different than anything in my Tacoma. After a week I don’t notice it anymore. My guess is your truck has always made that sound and you’re just now noticing it. Can’t hurt to get it checked out though.
  12. Aug 9, 2018 at 3:07 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    take off your stock antenna and check i get the same noise mine was from that.
  13. Aug 9, 2018 at 8:18 AM
    Evader53
    The noise is hard to hear in the video. Service tech at the dealer was able to hear the sound on the drive and agreed he’d never heard it before in any other tundra.
    It’s definitely not the throttle body screen noise, I can hear that whistle but it doesn’t bother me at all.
    My father was in the truck on the road trip and began hearing the sound the same day, without me mentioning it at all.
  14. Aug 9, 2018 at 1:58 PM
    Evader53
    Update: dealer confirmed noise is abnormal and suspects it to be the rear differential. They’ve ordered a new third member, should be repaired tomorrow. Fingers crossed that solves the issue
  15. Aug 9, 2018 at 2:03 PM
    geno0506
    geno0506 New Member
    Michael
    I was driving back from Austin on the toll road doing about 80mph and heard a noise for the first time that sounded like a kazoo!
  16. Dec 13, 2018 at 5:25 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    Mine just started doing this in November, the first time was during a cold startup for maybe 10 seconds. Now it doesn't do it at start up but right around 2050 to 2150 rpm then goes away once out of the rpm range, very much like a kazoo or a whirring sound, checked my fan and it spins freely, tried it with a/c on and a/c off and right around 2100 rpm I get the sound. Wont always do it otherwise would rev engine in park and try to track down. Was thinking a pulley or maybe AIP issue?
  17. Dec 13, 2018 at 9:09 AM
    Pupule Mike
    Pupule Mike New Member
    2015 Tundra Limited Crew Max
  18. Dec 13, 2018 at 9:38 AM
    Trikerider
    2015 Limited CM
  19. Dec 13, 2018 at 9:42 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    it sounds like feedback coming back through your phone or bluetooth audio?
  20. Dec 13, 2018 at 9:46 AM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Well this thread is dated in August. I can only imagine the op got the 3rd member installed from dealer by now. Wonder if that fixed it. @Evader53 was your problem solved?
  21. Dec 13, 2018 at 10:10 AM
    Trikerider
    2015 Limited CM
    The sound is similar to feedback noise but definitely engine related. Seamed to be a couple posts about it but no resolution, guess a trip to the dealer is in order and hopefully I can repeat the noise, figure its powersteering, AIP or pulley.
  22. Dec 13, 2018 at 2:52 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    I also had a rear diff installed at 700 miles on a 2018 sr5 4x4.
    I noted a high pitched whine from the rear of the vehicle at ~55mph with light throttle, very similar to what the op's video sounds like.
    A new differential solved it the noise.
  23. Jan 5, 2019 at 11:18 AM
    Trikerider
    2015 Limited CM
    Since resolutions are rarely posted, I replaced the pcv valve and it appeared to fix the whine/whir. The old valve was definetly not as ‘free’ as the new one.
    lewi3069 and pickeledpigsfeet like this.
  24. Aug 22, 2021 at 11:14 AM
    vman82
    vman82 New Member
    2021 Toyota Tundra Crewmax Limited
    I have this similar issue on my 2021. Any updates on what the problem was?
  25. Aug 22, 2021 at 1:36 PM
    vman82
    vman82 New Member
    Mine does it at about 30 mph and up... It's loud enough that my 8 year old daughter won't sit in the backseat. It's even louder if I slightly open the back window. I only have 1400 miles on the truck. Could it be the fuel pump?
    batman900[QUOTED] likes this.
