Which TPMS for TRD Wheels?
Discussion in 'Wheels & Tires' started by Cwalker417, Dec 29, 2024.
  1. Dec 29, 2024 at 6:46 AM
    Cwalker417
    Cwalker417 [OP] New Member
    Happy Holidays, I recently had the dreaded blinking tire pressure light come on. My truck is a 2016 1794 that had the stock 20" aluminum wheels on it originally. I now have the TRD BBS 18" wheels on the truck. When I swapped them, I assume the tire shop just threw in the original ones into the TRD wheels, havent really had any issues since. After doing some research it seems there are 2 different types of TPMS sensors that are out there, with different serials, angles of the sensor, etc. Anyone have any insight into what the correct part number is that I need to put into the TRD wheels to make sure they communicate to the truck?
    Thanks!
  2. Dec 30, 2024 at 9:08 PM
    H20ne
    H20ne New Member
    California
    2021 Limited Nightshade CM 4x4
    aFe, TRD, Eibach, RCI
    I used Denso 5500118 sensors on my 2021 Limited and they paired with the truck just fine by following the pairing method outlined in the owners manual. Been working fine.
  3. Dec 30, 2024 at 11:59 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    One type is only for steel wheels and the other is for everything else. Best to put your Vin in the parts catalog and the part number that comes up is what your original aluminum wheels would take and what your bbs would also take since they are also alloy.
