Which shifter?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BIGUGLY, Oct 7, 2017.
  1. Oct 7, 2017 at 6:51 AM
    BIGUGLY
    BIGUGLY [OP] I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Looking for some advice. I have a cement colored limited crew max and am looking into the AJT design shifter. The interior is black leather and wanting advice on which color of shifter to get. Thinking the machine black with blue bolts since the climate control has a blue tone to it. Or maybe the polished look with the machined clear with either blue bolts or the black bolts.
    Not sure if the black shifter would be too dark with the dark interior.
    Chime in please.
    Thanks
  2. Oct 7, 2017 at 7:14 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Post a pic of your interior. Also when I got mine I put 10mm flex tubing over the shifter shaft up to the threads and snugged the ajt shifter down on it a bit. There is a fair amount of negative space between the shaft (ha) and the shifter. Also keeps from having the 1/4 inch or so of the....shaft...sticking out of the bottom. Looked at it both ways and the flex tubing way looks better to me. It was like 4 bucks. 20170714_142705.jpg 20170714_143612.jpg
  3. Oct 7, 2017 at 7:38 AM
    BIGUGLY
    Paul
    2018 Limited
    Thanks Bak, I will go with the longer shifter, just looking to see if the black is too dark with a black leather interior
  4. Oct 7, 2017 at 9:10 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Big Ug the one I have is the longer one. If I had a dollar every time I said that..... Anyway here is another pic. You can't go wrong with black on black. Maybe wrap your three wood or black trim pieces in the dash a brushed metal and get the silver looking shifter. Or wrap the trim to match what ever color shifter you get. 3m will send you color samples I think. Here is the side pic of the long shifter installed and another of my brown lame wood trim wrapped in grey c.f..20170714_143546.jpg 20170706_114529-1.jpg
  5. Oct 7, 2017 at 9:19 AM
    BIGUGLY
    Paul
    2018 Limited
    Thanks much, that black looks good.
