Which leveling kit is compatible with the factory OEM bilstein loaded struts?
Discussion in 'Suspension' started by jwestford, Nov 28, 2021.
  1. Nov 28, 2021 at 9:53 AM
    jwestford
    jwestford [OP] New Member
    Jerry
    07 tundra TRD Limited
    Level kit
    My main question i have today is, I bought brand new bilsteins struts for the front end suspension and I need to know what level kit is compatible with the factory OEM bilstein loaded struts? I bought rough country but I don't think they fit with the bilsteins(2.5 inch)
  2. Nov 28, 2021 at 10:55 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You bought factory replacement Bilstein shocks? Not to clear on what you’re asking here. But if you’re using a spacer kit to level the truck, it just fits between the top of the assembly and the frame. You don’t need to do anything to the shock.
  3. Nov 28, 2021 at 11:18 AM
    jwestford
    Jerry
    Level kit
    Dan thanks I know how it works I'm looking for a compatible brand spacer kit/leveling kit that will fit with the New bilsteins?
  4. Nov 28, 2021 at 11:21 AM
    Danman34
    Danman34 New Member
    Danny
    Whichever kind says it’s fits the year model of your truck…
    jwestford[OP] likes this.
  5. Nov 28, 2021 at 11:28 AM
    jwestford
    Jerry
    Level kit
    Maybe I should ask it better, does anyone know what brand level kit goes best with Toyota factory OEM bilstein struts?
  6. Nov 28, 2021 at 11:34 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Man, you have been told and you still don't listen.
    Spacers have nothing to do with whatever brand of shock you choose.
    Pull up a schematic on Toyota struts and look how spacers are used.
  7. Nov 28, 2021 at 11:47 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Why do you think it won't fit?
  8. Nov 28, 2021 at 11:47 AM
    jwestford
    Jerry
    Level kit
    thanks guys I guess it's not rough country then. I'll look into putting the RC spacers then.
  9. Nov 28, 2021 at 12:03 PM
    jwestford
    Jerry
    Level kit
    Not sure I'm not a mechanic but was told RC not compatible with bilsteins.
  10. Nov 28, 2021 at 12:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Why not just use Bilstein 5100 front and rear and forgo the spacer kit completely?
    Not what you asked, but seems like the logical solution.
    You'll find far and few around here that will recommend a spacer lift/level.
    If you need to lift the rear, then go with Toytec shackles.
    Or if you're dead set on a spaver level/lift, good luck.
    Not really understanding your question though.
  11. Nov 30, 2021 at 8:03 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    the cheap spacer lifts are all basically the same. Does not matter if you are running stock shocks or any other shock (as long as the shock is a factory replacement-non lifted). So choose whatever spacer lift/level you want.
    But look in the suspension forum here at the stickies for pros/cons on the different types of lifts. Spacer lifts are cheap, which is a pro for some, but they have disadvantages as well.
    1lowlife likes this.
