Which hitch!?
Discussion in 'Towing & Hauling' started by Ipaddick, Aug 10, 2024.
  1. Aug 10, 2024 at 12:45 PM
    Ipaddick
    Ipaddick [OP] New Member
    Canada
    Platinum hybrid w/advanced package
    Hey all,
    looking to upgrade my current wdh. I have a third gen tundra hybrid, with bags.
    my trailer is about 6k lbs dry. About 31ft including hitch.
    debating hard between the b&w continuum and the safe weight middleweight. Which and why?
    b&w looks super easy to hook up.
    I want something that will maximize safety, but also want something easy to hook up and go. I currently have an old style chain curt wdh, with two friction sway bars and it’s a pita.
    anyone experience one or both?
    Thanks.
  2. Aug 10, 2024 at 4:06 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have heard good things about the B&W after they got some initial issues worked out. It seems easy to use.
    I have an original Weighsafe with the square bars probably more for the heavier trailers and my trailer comes in at around 4,200 lbs. I have dialled my Weighsafe in after about 4 years of using it and I find it easy to load and unload. I don't adjust it these days, I just stick it on the truck and look at the scale to see my tongue weight (usually the same each time). I use the tongue jack to take the pressure off the bars so I can slip them on and off with ease.
    The trailer seems fine consider the bars are stiffer than what they are offering now. I thought about getting the lighter bars but figured I don't need to change anything at the moment.
    Ipaddick[OP] likes this.
  3. Oct 21, 2024 at 10:15 AM
    JRS
    JRS New Member
    2012 DCLB
    Either of you get the B&W? I talked with the engineer who developed it to address my main concerns and he walked me through their testing, as well as validating using a hydraulic cylinder in a load-holding conifg (generally a no-go use case). It had been in the works for a decade prior to its release. All seems good but I have zero experience with WDHs. Would like to hear from this group.
  4. Oct 21, 2024 at 11:22 AM
    Ipaddick
    Canada
    Not yet. Waiting till spring, or hopefully a good sale.
    JRS[QUOTED] likes this.
  5. Oct 21, 2024 at 12:21 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Using the hydraulics to hold the load is basically the same thing the Weighsafe does. I think it can move dynamically as the load on the loadbars changes due to fluctuations in the road. The loadbars on the B&W are probably going to absorb more of this load. The Weighsafe bars are stiff but they new middleweight bars should flex a bit more for lighter trailers.
    The scale in the Weighsafe design provides some absorption of the fluctuating loads. I was going to stick my GoPro out there to watch the scale while driving but haven't gotten around to it.
    I think the main concern that I have is how low the bars hang on the B&W system. Other than that, I think it would be a great system.
  6. Nov 5, 2024 at 9:16 PM
    Florida AF
    Logan
    North Florida
    I have been mostly happy with my blue ox WDH. I am going to end up selling it and going with a propride, but I am heavier than you and also pulling a sail.
