Which diff and transfer case oil?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wes, Sep 6, 2018.
What brand
Poll closed Sep 9, 2018.
  1. Mobile 1
    66.7%
  2. Toyota
    33.3%
Multiple votes are allowed.
  1. Sep 6, 2018 at 4:10 PM
    Wes
    Wes [OP] New Member
    What oil 75-90?
    mobile 1 or toyota ?
    Any tips before I do diff and transfer case ?
  2. Sep 6, 2018 at 4:12 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    T-case is 75w so Toyota or Ravenol
    Diffs whateber floats your boat
    15whtrd likes this.
  3. Sep 6, 2018 at 6:35 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I went with Redline Oil for my Diffs, Tcase is Toyota or Ravenol like 14burrito mentioned.
  4. Sep 6, 2018 at 6:44 PM
    Wes
    Wes [OP] New Member
    Is Toyota oil $$$$
  5. Sep 6, 2018 at 6:54 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    For the t-case oil yes its not cheap.
  6. Sep 6, 2018 at 7:06 PM
    tacomawv
    tacomawv New Member
    Richard
    Is the ravenol oil the same. I have been putting off the TC due to the cost off the Toyota oil.. Also I went red line in the diffs.
  7. Sep 8, 2018 at 8:19 AM
    jstrenn
    jstrenn New Member
    2017 Toyota Tundra Double Cab 4X4 TRD Off Road
    Always remove your fill plug before you remove the drain plug. Otherwise if you have difficulties removing the fill plug after you drained it you won't be able to drive it somewhere for help.
  8. Sep 9, 2018 at 9:27 AM
    Wes
    Wes [OP] New Member
    Ok thank you guys so much for the help in going to change my diff right now
  9. Sep 11, 2018 at 12:24 PM
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    I went with Amsoil Severe Gear in the diffs. With my use, I should be able to get 75k miles without having to change it again.
  10. Sep 12, 2018 at 7:14 PM
    okieblow
    okieblow New Member
    Oklahoma
    2014 Tundra Crewmax Limited 4x4
    Just did front and rear diff last weekend with Red Line 75w85 for my 2014.
