Where to start with bolt on mods???
Discussion in 'Performance and Tuning' started by Jonny Bones, Aug 15, 2019.
  1. Aug 15, 2019 at 8:07 AM
    Jonny Bones
    Jonny Bones [OP] New Member
    Baltimore
    2019 cement limited crew max
    I want to install a trd exhaust on my new truck. I have heard mixed reviews about the TRD CAI so that’s up in the air. What other mods would you recommend for bolt on hp increase?
    Mountun Goat likes this.
  2. Aug 15, 2019 at 8:27 AM
    15whtrd
    15whtrd Mr. Blonde
    Long tube headers with custom duals out the back and supercharger. Short of that you’re really not going to gain much. You may gain a little with the TRD intake. I doubt you’ll gain anything from the TRD exhaust. In stock form these trucks do best with a single tail pipe outlet.
    Some people like a custom Dap tune but I don’t think that’s available for the 19s yet. As well as any supercharger tuning.
    I’m running the bully dog, and a dirty deeds muffler with a high flow air filter. The gains are marginal. Feels a little quicker and sounds 100 times better. But that could be the but dyno.
    One other trick that I haven’t used is the coolant bypass mod for the throttlebody. You just loop the coolant lines that go to the throttlebody so that it doesn’t get hot coolant lowering your AIT’s.
    It takes some serious coin to get these things in quicker. Long tubes and a custom tune and exhaust would be the best bang for the buck, short of the supercharger LOL.
  3. Aug 15, 2019 at 8:50 AM
    Factory intake is a CAI. Don't waste your money. Most of us use a drop in filter and have the SABM.
    Mountun Goat and 15whtrd like this.
  4. Aug 15, 2019 at 9:33 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    A dyno tune for high octane fuel (and any other upgrades you bolt on) would unlock peak power also. Advance the timing for high octane.
    15whtrd and Black Wolf like this.
  5. Aug 16, 2019 at 1:20 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give a call. I’ll help with:
    Throttle body coolant bypass
    Stock air box mod
    Gearing
    Tuner
    Catback
    Or:
    Nitrous
    Supercharger
    Turbo
    CaptJim1794 and Black Wolf like this.
  6. Aug 16, 2019 at 1:44 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looks no further than Keith at dirtydeeds!!! He's your man for performance upgrades
    dirtydeeds likes this.
  7. Aug 16, 2019 at 2:54 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Supercharger comes with a CAI
  8. Aug 16, 2019 at 3:33 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Does the Coolant bypass do anything in your opinion and how do you do it..
  9. Aug 18, 2019 at 5:25 AM
    dirtydeeds
    Keith
    USA
    Loop the coolant hoses leading to the throttle body, keeping the throttle body out of that loop
    It’s minimal gains. But long term overall, it’s gains. And it’s free.
  10. Aug 18, 2019 at 5:33 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Is it a good idea to run long tubes with a super charger?
  11. Aug 18, 2019 at 5:35 AM
    dirtydeeds
    Keith
    USA
    I’ve tested multiple exhaust systems on multiple trucks with and without a supercharger. There’s no need to run long tubes with a supercharger. Just a simple bolt on Catback is all you need.
    Rex Kramer likes this.
  12. Aug 19, 2019 at 12:24 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Would a S/C Tundra not benefit from LT Headers more then a N/A engine? I would imagine that more air in makes more air out...but if you can swing that model to even let more air out, there has to be some noticeable benefits to pairing a LT header exhaust system to a S/C'd engine...right?
    Saltyhero13 likes this.
  13. Aug 19, 2019 at 1:24 PM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    LT’s with a S/C would benefit greatly but from what I’ve read, tuning and fuel becomes the issue. That’s why nobody does it
    focal likes this.
  14. Aug 19, 2019 at 1:26 PM
    HulkSmurf14
    2014 Tundra Limited
    ^^Gotcha...that makes the best sense. Thanks!
  15. Aug 20, 2019 at 9:37 AM
    dirtydeeds
    Keith
    USA
    A supercharged engine is not a naturally aspirated engine. At least not a tvs1900 charged engine.
    A turbo or centrifugal supercharger acts like a naturally aspirated engine and benefits from ‘air out’. But a twin screw forces in the air, and it gets forced out too.
    I’ve tested our trucks with the very best exhaust and the very worse exhaust (melted cats literally a brick blocking the exhaust flow). Said truck had exactly the same times with headers and race exhaust, stock exhaust, headers and melted cats.
    The tvs1900 doesn’t care what exhaust is on your truck. It will flow air if the rotors are spinning.
    A turbo or centrifugal supercharger will cavitate the air since it’s not forcing it. Neither is ‘positive displacement’. So they will tend to act more like NA and want better exhaust.
    Best advice I can give when supercharged with a TVS1900, choose a flow thru style muffler to reduce the pressure and heat, but don’t waste the $$ on a full race system with headers etc.
    Call for details. 760-877-4234
    Weeble19 likes this.
  16. Aug 20, 2019 at 6:48 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Supercharger is a good bolt on mod
    Saltyhero13 and dirtydeeds like this.
  17. Aug 21, 2019 at 4:59 AM
    Jonny Bones
    Baltimore
    Maybe one day, when the kids are grown.
  18. Aug 22, 2019 at 1:18 AM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    You can put a turbo on a 5.7 tundra? :eek:
    dirtydeeds[QUOTED] likes this.
  19. Aug 22, 2019 at 7:23 AM
    dirtydeeds
    Keith
    USA
    I have a good friend been running one for several years. And I have a turbo on my first gen tundra.
  20. Aug 22, 2019 at 8:54 AM
    Jonny Bones
    Baltimore
    Does adding the dirty deeds exhaust to the truck void the warranty? I was under the impression that replacing the exhaust with TRD system doesn't void it.
  21. Aug 22, 2019 at 9:08 AM
    dirtydeeds
    Keith
    USA
    Exhaust does not void factory warranty unless it was the actual cause of a failure. Which exhaust can’t cause a rear end, tranny, or engine to blow up. Etc.
    Angry Gunny likes this.
