Where to get calipers powder coated?
Discussion in 'Wheels & Tires' started by TedTundy, Jan 11, 2021.
  1. Jan 11, 2021 at 9:36 AM
    TedTundy
    TedTundy [OP] New Member
    Chad
    Michigan
    2020 Super White TRD Pro
    Center Console Safe, Rove R2-4K
    I want to get my calipers painted red. Right now the stock uncoated ones look bland.
    I have a powder coater that I do business with sometimes, but I don't want to disassemble the rotors and bleed brakes and all that stuff myself since I don't know how to.
    Is there a company that does caliper powder coating?
    I live in Metro Detroit Michigan
  2. Jan 11, 2021 at 9:40 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Most P/C. places can do most anything. If your asking to do powder coating while still installed, then probably not. The prep work and process will require them to be removed.
  3. Jan 11, 2021 at 10:09 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I believe many just paint them, installed and all. Just mask off areas around it.
    Spray or Brush on. I've heard brush on is easier to control and lasts longer.
    http://www.northernautoparts.com/ProductDetail.cfm?ProductId=2565
    regarding power coating: Call a few shops and ask, that will give you a definitive answer. Even if my shop does it here, yours might not. But to be honest, I don't think you'll find a PC shop that will do the bleeding and removing.
  4. Jan 11, 2021 at 10:13 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I don't think that a powder coat shop will want to put used calipers into their oven. Any off gassing can cause contamination issues with their equipment. Contamination is the biggest adhesion and cosmetic issue for a powder coater. Another thing to consider is what will the powder coating do at high brake temperatures.
  5. Jan 11, 2021 at 11:07 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    It will be very $$$ for a coater to strip and clean a used caliper. Best to paint and clear.
  6. Mar 29, 2021 at 11:26 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I know I'm a little late to this party but I was on here searching if anyone had pictures of painted calipers on the tundra with TSS wheels and saw this post. I've done 3 of my own cars with the dupli color BCP400 ceramic paint Kit (brush on) which is $25 on Amazon right now. I have had great results with it.
    I painted the calipers on one car that had 110k miles on it up here in the rust belt. I just took my time and a dremel with a couple wire wheels to get the crud off then cleaned them REALLY well with some brake cleaner, use plenty of brake cleaner (well ventilated area). Its all in the prep work. I put another 90k miles on that car before I got rid of it and a quick blast from the electric pressure washer and they always looked brand new. my biggest issue with doing the ones on the tundra is having enough room to get it up on 4 jack stands so I can take my time to do the job and let it sit for a day or two.
    Trooper2 likes this.
